Product
Samsung 256GB 860 Pro Series SATA 6Gb/s SSD
Quicklinx: DBCGWS00 Mfr#: MZ-76P256B/EU
Form Factor: 2.5"
Capacity: 256GB
Interface: Serial ATA-600
Type: Internal hard drive
£84.18 ex VAT
£101.01 inc VAT
Express delivery Order within the next 16 hours for delivery tomorrow
THE SAMSUNG SSD 860 PRO
The Samsung SSD 860 PRO is the new Samsung’s Client-PC SATA SSDs, specially designed for high-end computing devices. Building on the reputation of the Samsung SSD 850 PRO, the world’s first V-NAND SSD for Client PCs, the new Samsung SSD 860 PRO drives achieve top class performance for SATA SSDs, offering improvements in speed, reliability, and compatibility. The 860 PRO comes equipped with Samsung’s newly designed MJX controller along with the latest 2bit MLC V-NAND architecture.
Professional Performance
The legacy Serial-ATA (SATA) interface faces the theoretical bandwidth limitation of 600MB/s which many SSD manufacturers have tried to reach over the years. Among them, Samsung, which first brought V-NAND technology to the market through the 850 PRO, continuously strives to improve product reliability and performance, even with the SATA interface limitations. Powered by Samsung’s latest 64-layer 2bit MLC V-NAND technology, the 860 PRO, the successor of the 850 PRO, delivers best-in-class sequential read (up to 560 MB/s) and write (up to 530 MB/s) speeds and along with high sustainable performance for the professionals who always pursue best achievement.
Ultimate Reliability
The 860 PRO offers guaranteed endurance and ultimate reliability, with up to approximately 8 times higher Total Bytes Written (TBW) than the 850 PRO and an industry-leading 5-year limited warranty. Up to 4,800 TBW powered by the latest V-NAND technology, which is the highest TBW rating industry-wide, will give you absolute confidence in your SSD (1).
Furthermore, the 860 PRO assures long-term dependable performance with minimal performance degradation. The 860 PRO provides up to 25% better sustained performance compare to that of its predecessor. This means you can experience the high performance of the SSD even with heavy daily workload.
Smart Compatibility with a Refined Controller
The 860 PRO delivers expanded system compatibility. The refined ECC algorithm and revamped controller generate strong sustainable performance near SATA’s limits, and the improved queued trim provides for better Linux compatibility. The 860 PRO is uniquely designed for not only Client-PCs but also NASs (Network Attached Storages) and workstations thanks to its Samsung 2bit MLC V-NAND composition.
Advanced Data Encryption
The 860 PRO provides multiple advanced data encryption features. Self-Encrypting Drive (SED) security technology will help keep data safe at all times. The 860 PRO includes an AES 256-bit hardware-based encryption engine to ensure that your personal files remain secure. Being hardware-based, the encryption engine secures your data without the performance degradation that you may experience with software-based encryption. Also, the 860 PRO is compliant with various advanced security management solutions (TCG Opal and Encrypted Drive-IEEE1667).
Samsung Data Migration and Magician Software
The 860 PRO comes with Samsung Data Migration and Magician software, which is easy to install and makes management of you SSD simple.(2) Samsung Data Migration software is easy to use, yet provides a very powerful "Custom Cloning" feature that makes migration effortless even when the source data is greater than the SSD’s capacity. Magician provides personalized firmware checks and additional functions tailored for individual users’ drives. It even updates the firmware automatically to make sure that the drives’ performance stays up to date.
(1) All documented endurance test results are obtained in compliance with JESD218 standards. Please visit www.jedec.org for detailed information on the standard.
(2) To download Samsung Data Migration and Magician, please visit www.samsung.com/samsungssd
Samsung 860 PRO MZ-76P256B - solid state drive - 256 GB - SATA 6Gb/s
Solid state drive - internal
256 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
512 MB
TRIM support, sleep mode, 3D V-NAND Technology, Auto Garbage Collection Algorithm, eDrive, Samsung MJX Controller, Low Power DDR4 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667
69.85 mm x 100 mm x 6.8 mm
50 g
5 years warranty
256 GB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
Buffer Size
512 MB
69.85 mm
100 mm
6.8 mm
50 g
Performance
SSD Endurance
300 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
560 MBps (read) / 530 MBps (write)
Maximum 4KB Random Write
90000 IOPS
Maximum 4KB Random Read
100000 IOPS
Reliability
MTBF
2000000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
1 Watt (average) , 3.3 Watt (maximum)
WWN, IEEE 1667
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms
Form Factor: 2.5"
Capacity: 256GB
Brand: Samsung
Price Range Ex VAT: 50 - 100
