Samsung 250GB T5 Series USB 3.1 Type-C External Portable SSD
Clearance!
Clearance
Last Few Remaining
Limited Time Offer
Quicklinx: D2HJWS00 Mfr#: MU-PA250B/EU
Form Factor: 2.5"
Capacity: 250GB
Interface: USB 3.1 Gen 2
Type: External hard drive
Select:
Hurry, only 2 left in stock!
£66.91 ex VAT
£80.29 inc VAT
Storage Redefined
The Samsung Portable SSD T5 elevates data transfer speeds to the next level and unleashes a new experience in external storage. With a compact and durable design and password protection, the T5 is truly easy to carry and stores data securely.
Fast Transfer Speeds
With Samsung V-NAND flash memory and a USB 3.1 Gen2 interface, the T5 provides fast transfer speeds of up to 540MB/s, that's up to 4.9x faster than external HDDs. Transfers and backups of large-sized data including 4K videos and high-resolution photos will be much quicker and faster.
Download times from laptop to T5:
4.8GB 4K UHD Movie - 12 seconds
3GB Full HD Movie - 7 seconds
100 Photos (2.8MB each) - 3 seconds
Metal Minimalism
The top to bottom metal design and rounded unibody fits comfortably in the palm of your hand. The T5 comes in two distinct aluminum finishes - an alluring blue for 250GB and 500GB models, and a deep black for 1TB and 2TB models.
Compact and Light
Smaller than the average business card, weighing just 51 grams, and only 10.5mm thick. The compact, light and slim T5 is the perfect portable storage.
Solid Inside and Out
Stay worry-free. The T5 has no moving parts and a sturdy metal body, so it can handle drops of up to 2 metres. The optional password protection with AES 256-bit hardware encryption keeps your personal and private data more secure. It's all confidently backed by a 3-year limited warranty.
Management Software
The T5 comes embedded with new intuitive software for PCs and Macs to easily set the password and get the latest firmware updates. You can also download the mobile app for Android smartphones and tablets.
Connect with ease
Connect the T5 to an extensive range of devices from PCs, Macs, smartphones and other devices. The included USB Type C to C cable and USB Type C to A cable give you seamless connectivity without the hassle of purchasing additional adapters.
Ready anytime, anywhere
Take everything, all your work and entertainment, with you. The Portable SSD T5 gives you simple and efficient access to your massive data so you can complete tasks quickly and on the move. Take along your documents, large-sized photos or videos, and get things done wherever you go.
Storage Capacity
250GB:
4K UHD Video - 3840 x 1600 (24fps), 4.83GB, 1:48:53 - 80 hours
HD Video - 1920 x 804 (24fps), 2.99GB, 1:58:36 - 150 hours
Photos - 2.8MB each - 80,000
  • Fast transfer speeds
    With Samsung V-NAND flash memory and a USB 3.1 Gen 2 interface, the T5 provides fast transfer speeds. Transfers and backups of large-sized data, including 4K videos and high-resolution photos, will be much quicker and faster.
  • Metal minimalism
  • Compact and light
    Smaller than the average business card, weighing little and thin. The compact, light and slim, T5 is the perfect portable storage.
  • Solid inside and out
    Do more. Worry less. The T5 has no moving parts and a sturdy metal body, so it can handle drops.
  • Connect with ease
    Connect the T5 to an extensive range of devices from PCs, smartphones and other devices.
Samsung Portable SSD T5 MU-PA250 - solid state drive - 250 GB - USB 3.1 Gen 2
Solid state drive - external (portable) - shock resistant, password authentication, USB Attached SCSI Protocol (UASP) compliant, V-NAND Technology
250 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.1 Gen 2 - USB-C
Shock resistant, password authentication, USB Attached SCSI Protocol (UASP) compliant, V-NAND Technology, 256-bit AES
Power Source
USB bus
Enclosure Colour
Ocean blue
7.4 cm x 1.05 cm x 5.73 cm
51 g
3-year warranty
250 GB
Hardware Encryption
256-bit AES
USB 3.1 Gen 2
7.4 cm
1.05 cm
5.73 cm
51 g
Performance
Max Data Transfer Rate
540 MB/s
Expansion & Connectivity
1 x USB 3.1 Gen 2 - 24 pin USB-C
Power Source
USB bus
USB-C cable
UL, TUV, VCCI, C-Tick, BSMI, CB, IC, FCC, KC, RoHS2, EAC, UASP (USB Attached SCSI Protocol)
Enclosure Colour
Ocean blue
Limited warranty - 3 years
Form Factor: 2.5"
Capacity: 250GB
Brand: Samsung
Price Range Ex VAT: 50 - 100
