Your basket is empty
Samsung 250GB mSATA 6GBp/s 850 EVO SSD
Quicklinx: B8KHWS00 Mfr#: MZ-M5E250BW
Form Factor: mSATA
Capacity: 250GB
Interface: Serial ATA-600
Type: Internal hard drive
Stock Status: Clearance
£77.57 ex VAT
£93.08 inc VAT
Express delivery Order within the next 17 hours for delivery on Monday
Achieve the ultimate read/write performance to maximize your everyday computing experience with Samsung's TurboWrite technology. You not only obtain more than a 10% better user experience but up to 1.9x faster random write speeds. The 850 EVO delivers the top of its class performance in sequential read and write speeds. Plus, you also gain optimized random performance in all QD for client PC usage scenario.
Samsung's Magician software which provides rapid mode for 2x faster processing data speeds on a system level by utilizing unused PC memory (DRAM) as cache storage. The Magician increased the maximum memory usage in rapid mode. You also get a 2x performance boost in all random queue depth.
The 850 EVO delivers significantly longer battery life on your notebook with a controller optimized for 3D V-NAND now enabling device sleep at a highly efficiency. The 850 EVO is now 25% more power efficient during write operations thanks to 3D V-NAND only consuming half the energy than that of planar 2D NAND.
Samsung 850 EVO MZ-M5E250BW - solid state drive - 250 GB - SATA 6Gb/s
Solid state drive - internal
250 GB
Hardware Encryption
mSATA
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
512 MB
TRIM support, DevSleep mode, 3D V-NAND Technology, Auto Garbage Collection Algorithm, Worldwide Name (WWN), Samsung MEX Controller, S.M.A.R.T., 256-bit AES, IEEE 1667
30 mm x 50.8 mm x 3.81 mm
9.07 g
5 years warranty
250 GB
Hardware Encryption
mSATA
SATA 6Gb/s
Buffer Size
512 MB
30 mm
50.8 mm
3.81 mm
9.07 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 520 MBps (write)
Maximum 4KB Random Write
88000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 52 pin mini-SATA
Compatible Bay
mSATA
Power Consumption
50 mW (active) , 2.3 Watt (average) , 3.6 Watt (maximum)
Software Included
Samsung Magician Software
Limited warranty - 5 years
70 °C
Shock Tolerance (non-operating)
1500 g @ 0.5 ms half-sine pulse
Samsung 250GB mSATA 6GBp/s 850 EVO SSD Bundle deal on Samsung 250GB mSATA 6GBp/s 850 EVO SSD
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.33 | in stock
£80.24
saving £2.67
Including:
£80.24
saving £2.67
Form Factor: mSATA
Capacity: 250GB
Brand: Samsung
Price Range Ex VAT: 50 - 100
