Samsung 250GB 750 Evo Series SATA 6Gb/s 2.5" SSD
Quicklinx: BZ66WS00 Mfr#: MZ-750250BW
PC users are choosing high-speed SSDs for better computing performance and reliability. The Samsung 750 EVO SSD, with a SATA 6 Gb/s interface, is an outstanding high-performance choice for an enhanced everyday computing experience. With sequential read and write speeds up to 540/520 MB/s and random read and write speeds up to 97,000/88,000 IOPS, you will find yourself handling multitasking faster than before.
The 750 EVO boasts a fast computing experience thanks to TurboWrite technology and RAPID mode. TurboWrite technology accelerates sequential write speeds by creating a write buffer inside the SSD. Magician software provides the option to enhance PC performance with RAPID mode, which processes data on a system level using unused PC memory (DRAM) as a cache.
The 750 EVO features SED technology to help keep your data safe. An AES-256-bit hardware-based full disk encryption engine secures your data with significantly less performance degradation often experienced with software-based encryption. And the 750 EVO is compliant with TCG 2 Opal v2.0 standards and IEEE 3 1667 protocol.
Series: Samsung 750 EVO
Capacity: 250GB
Form Factor: 2.5"
Interface: SATA3 (6Gb/s)
Controller: Samsung MGX controller
Read: 540Mbps
Write: 520Mbps
Max Random 4K R/W: "97,000 / 88,000 IOPS"
Power Consumption: Active Read/Write (Average): 2.4W / 2.8W
Weight/Dimensions: 45 g
100.00 x 69.85 x 6.80 mm
Operating Temperatures: 0-70C degrees
Shock Resistance: "1,500 G, duration 0.5 minutes seconds, 3 axis"
MTBF: 1.5 Million Hours
Package Type: Retail
Package Weight: 0.0900 kg
Warranty: 3 Years
  • Heighten your computing experience with fast performance
  • Enjoy superior computing for everyday use
  • Secure data through advanced data encryption
Samsung 750 EVO MZ-750250 - SSD - 250 GB - SATA 6Gb/s
Solid state drive - internal
250 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Hardware Full Disk Encryption (FDE), TRIM support, sleep mode, DDR3 DRAM Cache, Auto Garbage Collection Algorithm, Worldwide Name (WWN), RAPID mode support, TurboWrite Technology, Samsung MGX Controller, S.M.A.R.T., IEEE 1667
69.85 mm x 100 mm x 6.8 mm
45 g
3-year warranty
250 GB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
Buffer Size
256 MB
69.85 mm
100 mm
6.8 mm
45 g
Performance
SSD Endurance
70 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 520 MBps (write)
Maximum 4KB Random Write
88000 IOPS
Maximum 4KB Random Read
97000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Software Included
Samsung Magician Software
Limited warranty - 3 years
70 °C
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
