Samsung 240GB SM863 DC Enterprise 2.5" SATA 6Gb/s SSD
Quicklinx: C0Z5WS00 Mfr#: MZ-7KM240E
Samsung's SM863 SSDs with 2-bit MLC V-NAND are an ideal storage solution for write-intensive applications such as mail servers, data warehousing and high performance computing, providing high endurance for around the clock operations.
Samsung SM863 MZ-7KM240E - SSD - 240 GB - SATA 6Gb/s
Solid state drive - internal
240 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
TRIM support, DRAM cache, End-to-end data protection, 3D V-NAND Technology, Dynamic Thermal Guard protection, Enterprise Power-Loss Protection, Enterprise, 24x7 availability, Advanced ECC Engine, Mercury controller, S.M.A.R.T.
7.01 cm x 10 cm
63.5 g
5-year warranty
240 GB
2.5"
SATA 6Gb/s
7.01 cm
10 cm
63.5 g
Performance
SSD Endurance
1540 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
520 MBps (read) / 485 MBps (write)
4KB Random Read
97000 IOPS
4KB Random Write
20000 IOPS
Reliability
MTBF
2,000,000 hours
24x7 Operation
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
2.2 Watt (read) , 2.7 Watt (write)
Limited warranty - 5 years
70 °C
5 - 95% (non-condensing)
