Robust design
The Samsung T7 Shield is built to withstand the challenges of daily use with its shock-resistant feature, ensuring your data stays safe even when on the move. -
High-speed transfers
Experience fast data transfers with the Samsung T7 Shield, boasting an interface speed of 10.0 Gbps (USB 3.2 Gen 2) and a maximum data transfer rate of 1050 MB/s, making file sharing quick and efficient. -
Secure storage
With 256-bit AES hardware encryption, the Samsung T7 Shield offers strong security for your data, giving you peace of mind that your files are protected against unauthorized access.
 - Samsung T7 Shield MU-PE1T0R - SSD - 1 TB - USB 3.2 Gen 2
 - Solid state drive - external (portable)
- Capacity
 - 1 TB
- Hardware Encryption
- Encryption Algorithm
 - 256-bit AES
- Interface
 - USB 3.2 Gen 2 - USB-C
- Data Transfer Rate
 - 10.0 Gbps (USB 3.2 Gen2)
 - Shock resistant
- Power Source
 - USB bus
- Enclosure Colour
 - Blue
 - 88.15 mm x 13 mm x 59 mm
 - 98.5 g
 - 3-year warranty
- Capacity
 - 1 TB
 - 256-bit AES
- Interface
 - USB 3.2 Gen 2
 - Shock resistant
 - 88.15 mm
 - 13 mm
 - 59 mm
 - 98.5 g
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
 - 1050 MB/s
Expansion & Connectivity
 - 1 x USB 3.2 Gen 2 - 24 pin USB-C
- Power Source
 - USB bus
- OS Required
 - Microsoft Windows 7 or later, Android 5.0 or later, Apple MacOS X 10.10 or later
 - UL, TUV, VCCI, C-Tick, BSMI, CB, IC, FCC, IP65, KC, RoHS2
- Enclosure Colour
 - Blue
 - Limited warranty - 3 years
