Samsung 1TB T3 USB 3.1 External SSD
Quicklinx: BZ9WWS00 Mfr#: MU-PT1T0B/EU
Portability is the key element shared among all digital devices today where everything, including you, is constantly moving. When you are always on-the-go, your data should be, too. Born and bred with potent portability in its core, the Samsung Portable SSD T3 is built strong and light and is equipped with a built-in security feature. Most of all, it offers the blazing-fast data transfer speed of up to 450 MB/s. With compatibility across multiple operating systems and devices, the T3 will take your data to another level of accessibility.
  • Quick on its feet
    Reduce downtime with blazing-fast, 450 MB/s read/write speeds, up to 4x faster than traditional external hard drives.
  • Small, compact and light
    A strong, shock-resistant metal case and internal support frame handles the daily wear of professional life, yet weighs is low and is roughly the size of a business card.
Samsung T3 MU-PT1T0B - SSD - 1 TB - USB 3.1 Gen 1
Solid state drive - external (portable)
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.1 Gen 1 - USB-C
Data Transfer Rate
10.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Shock resistant, USB Attached SCSI Protocol (UASP) compliant, 256-bit AES
Power Source
USB bus
7.4 cm x 1.05 cm x 5.8 cm
51 g
3-year warranty
1 TB
Hardware Encryption
256-bit AES
USB 3.1 Gen 1
7.4 cm
1.05 cm
5.8 cm
51 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
450 MB/s
SSD Endurance
400 TB
Expansion & Connectivity
1 x USB 3.1 Gen 1 - 24 pin USB-C
Power Source
USB bus
Microsoft Windows 7 or later, Apple MacOS X 10.7 or later, Android 4.4 (KitKat) or later
UL, TUV, VCCI, C-Tick, BSMI, CB, IC, FCC, KC, RoHS2, EAC
Limited warranty - 3 years
