Samsung 1TB Portable SSD X5 Thunderbolt 3
Quicklinx: DRP4WS00 Mfr#: MU-PB1T0B/EU
Select:
  • 1TB
Samsung Portable SSD X5
Professionalism at its finest
Elevate your storage tasks to ultimate heights on PCs and Macs with Thunderbolt™ 3 ports. The X5 is designed for tech savvy professionals who want to render or compile high resolution contents faster than ever. Its thermal management and password protection offer both comfort and security.
Wield the power of Thunderbolt™ 3
Thunderbolt 3 and NVMe Interface
The X5 is here to quench your thirst for advanced technology. Thunderbolt 3 delivers the fastest bandwidth up to 40 Gb/s that brings lightning speed and performance. Equipped with the astonishing speed of NVMe interface, the X5 assists with handling heavier data at faster speeds.
  • Thunderbolt 3 and NVMe express interface
    The X5 is here to quench your thirst for advanced technology. Thunderbolt 3 delivers the fastest bandwidth up to 40 Gb/s that brings lightning speed and performance. Equipped with the astonishing speed of NVMe Express interface, the X5 assists with handling heavier data at faster speeds.
  • Data transfer speed
    Spend more time being creative. The X5's read/write speeds of up to 2,800/2,300 MB/s are 5.2x/4.5x faster than a Portable SSD with SATA interface and 25.5x/20.9x faster than an external HDD. The X5 lets you transfer a 20GB 4K UHD video from your PC to the X5 in just 12 seconds.
  • Revolutionary design
    You're special, so is the X5. Inspired by a supercar, its dynamic and streamlined shape highlights speed and a glossy top boasts premium quality. The practical matte bottom prevents slips when held. Enjoy maximised portability and optimised design equipped with state-of-the-art technology.
  • Thermal management technology
    Never worry about heat. The X5's DTG (Dynamic Thermal Guard) technology helps maintain optimal performance and temperature, and a heat sink keeps surface temperature below 45°C. Its body has no moving parts and is reinforced with magnesium alloy that can even withstand a 2m drop.
Samsung X5 MU-PB1T0B - SSD - 1 TB - Thunderbolt 3
Solid state drive - external (portable)
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
Thunderbolt 3 - USB-C
Data Transfer Rate
40 Gbps (Thunderbolt 3)
Dynamic Thermal Guard protection, NVM Express (NVMe), 256-bit AES
Power Source
Thunderbolt bus
Enclosure Colour
Grey
11.9 cm x 1.97 cm x 6.2 cm
150 g
3-year warranty
1 TB
Hardware Encryption
256-bit AES
Thunderbolt 3
Internal Drive Interface
PCI Express 3.0 x4 (NVMe)
11.9 cm
1.97 cm
6.2 cm
150 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
2800 MB/s
Data Transfer Rate Details
Thunderbolt 3 (read): 2800 MB/s , Thunderbolt 3 (write): 2300 MB/s
Expansion & Connectivity
1 x Thunderbolt 3
Power Source
Thunderbolt bus
UL, TUV, VCCI, C-Tick, BSMI, CB, IC, FCC, KC, EAC
Enclosure Colour
Grey
Limited warranty - 3 years
