The Samsung 850 PRO SSD redefines storage with the world's first drive based on 3D VNAND flash, offering exceptional read/write performance, reliability and power management efficiency. The 850 Pro delivers up to 2x the speed, density and endurance of conventional flash.
- The World's First Consumer 3D V-NAND SSD
- Ultimate Read/Write Performance
- Enhanced Endurance and Reliability
- Efficient Power Management
Samsung's 850 PRO, the world's first 32 layer 3D V-NAND, provides up to 100K IOPS Random Read Speed and 470 MB/s Sequential Write speed and the option of enabling Samsung RAPID mode, which can kick up to even higher speeds. With up to 2x the speed and density of conventional 2D flash, you get the most speed available for gaming and real world performance
With an industry-leading 10 year, 150 TBW warranty, the 850 PRO offers unbeatable reliability. When combined with the 850 PRO's 256-bit AES Self-Encrypting Drive (SED) security technology, you can rely on your files being secure and available whenever you need them.
Featuring a 4th generation MEX Controller, the 850 PRO offers one of the most energy-efficient drives on the market, using up to 50% less power than traditional hard drives. It has the lowest active write power consumption and supports device sleep mode, which lowers power consumption to under 2mW.
- 2.5" SATA III Solid State Drive
- 256GB
- SEQUENTIAL READ SPEED: Up to 550MB/s
- SEQUENTIAL WRITE SPEED: Up to 520 MB/s
Ultimate read/write performance
Samsung's 850 PRO, the world's first 32 layer 3D V-NAND, provides up to 100K IOPS Random Read Speed and 520 MB/s Sequential Write speed and the option of enabling Samsung RAPID mode, which can kick up to even higher speeds. With up to 2x the speed and density of conventional 2D flash, you get the most speed available for gaming and real world performance. -
Enhanced endurance and reliability
The 850 PRO offers unbeatable reliability. When combined with the 850 PRO's 256-bit AES Self-Encrypting Drive (SED) security technology, you can rely on your files being secure and available whenever you need them. -
Efficient power management
- Samsung 850 PRO MZ-7KE1T0BW - solid state drive - 1 TB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 1 TB
- Hardware Encryption
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 1 GB
- TRIM support, Automatic Garbage Collection, sleep mode, Samsung 3-core MEX Controller, Microsoft eDrive compatible, 3D V-NAND Technology, Low Power DDR2 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667
- 69.85 mm x 100 mm x 6.86 mm
- 66 g
- 10 years warranty
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 1 GB
- 69.85 mm
- 100 mm
- 6.86 mm
- 66 g
Performance
- SSD Endurance
- 150 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 550 MBps (read) / 520 MBps (write)
- 4KB Random Read
- 100000 IOPS
- 4KB Random Write
- 90000 IOPS
Reliability
- MTBF
- 2,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 4.5 Watt (active) , 0.4 Watt (idle)
- Software Included
- Drivers & Utilities, Samsung Magician Software, Samsung Smart Migration Software, Samsung Drive Manager
- Limited warranty - 10 years
- 0 °C
- 70 °C
- Shock Tolerance
- 1500 g @ 0.5ms half-sine pulse
