Product
Brand
Samsung 1TB 850 EVO mSATA 6Gb/s Solid State Drive
Quicklinx: BRP5WS00 Mfr#: MZ-M5E1T0BW
Achieve the ultimate read/write performance to maximize your everyday computing experience with Samsung's TurboWrite technology. You not only obtain more than a 10% better user experience but up to 1.9x faster random write speeds. The 850 EVO delivers the top of its class performance in sequential read and write speeds. Plus, you also gain optimized random performance in all QD for client PC usage scenario.
Samsung's Magician software which provides rapid mode for 2x faster processing data speeds on a system level by utilizing unused PC memory (DRAM) as cache storage. The Magician increased the maximum memory usage in rapid mode. You also get a 2x performance boost in all random queue depth.
The 850 EVO delivers significantly longer battery life on your notebook with a controller optimized for 3D V-NAND now enabling device sleep at a highly efficiency. The 850 EVO is now 25% more power efficient during write operations thanks to 3D V-NAND only consuming half the energy than that of planar 2D NAND.
Samsung 850 EVO MZ-M5E1T0BW - solid state drive - 1 TB - SATA 6Gb/s
Solid state drive - internal
1 TB
Hardware Encryption
mSATA
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
1 GB
TRIM support, DevSleep mode, 3D V-NAND Technology, Auto Garbage Collection Algorithm, Worldwide Name (WWN), Samsung MEX Controller, S.M.A.R.T., 256-bit AES, IEEE 1667
30 mm x 50.8 mm x 3.81 mm
9.07 g
5 years warranty
1 TB
Hardware Encryption
mSATA
SATA 6Gb/s
Buffer Size
1 GB
30 mm
50.8 mm
3.81 mm
9.07 g
Performance
SSD Endurance
150 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 520 MBps (write)
Maximum 4KB Random Write
88000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 52 pin mini-SATA
Compatible Bay
mSATA
Power Consumption
50 mW (active) , 4.3 Watt (average) , 5.7 Watt (maximum)
Software Included
Samsung Magician Software
Limited warranty - 5 years
70 °C
Shock Tolerance (non-operating)
1500 g @ 0.5 ms half-sine pulse
