Samsung LaserJet cartridge has been tested to meet ISO (International Organization for Standardization) standards, which makes it easy to compare toner yields from different manufacturers. With Samsung toner cartridge, you can be confident that you're making an informed buying decision.
Unique toner design
Samsung printer cartridge is small and light, ideal for personal, small or home office users. -
NO NOIS
Imagine a printer that operates quietly and allows you to concentrate on other important tasks while it prints. The NO-NOIS engine design means the toner is stored in a fixed cartridge mechanism, eliminating noise and vibration. It also simplifies toner changes - there are no heavy toners to change, just small, easy-to-access toner bottles. -
Genuine quality
Enjoy consistent print results. With Samsung supplys you're virtually guaranteed high quality pages without any defects. -
Easy-to-change toner
No mess. No fuss. Samsung printer cartridge is easy to replace so you can get back to work. Simply follow three easy steps: open the front cabinet, change the cartridge, and close the cabinet. That's all there is to it! -
Standardized cartridge
Samsung LaserJet cartridge has been tested to meet ISO (International Organization for Standardization) standards, which makes it easy to compare toner yields from different manufacturers. With Samsung toner cartridge, you can be confident that you're making an informed buying decision. -
Automatic toner monitoring system
Never get stuck on empty again. When toner is running low, the automatic toner monitoring system conveniently notifies you.
- Samsung CLT-Y4072S - yellow - original - toner cartridge
- Product Type
- Toner cartridge
- Printing Technology
- Laser
- Printing Colour
- Yellow
- Yield
- Up to 1000 pages
- Compatible with
- CLP-320, 320N, 325, 325W; CLX-3185, 3185FN, 3185FW, 3185N, 3185W
Consumable
- Consumable Type
- Toner cartridge
- Laser
- Yellow
- Included Qty
- 1-pack
- Yield
- Up to 1000 pages
- Compatible with
- Samsung CLP-320, 320N, 325, 325W , Samsung CLX-3185, 3185FN, 3185FW, 3185N, 3185W
