Your basket is empty
Samsung 19" HD ready, LED, Narrow bezel, rectangle stand - UE19H4000AWXXU
Quicklinx: 9GHCWS00 Mfr#: UE19H4000AWXXU
  • DVB-T
Samsung's HD Ready LED TV lets you experience stunning images, in a slim compact form.
Wide Colour Enhancer Plus
Using an advanced picture quality improvement algorithm, Samsung's Wide Colour Enhancer Plusdrastically improves the quality of any image and uncovers hidden details. Now see colours as they were meant to be seen with Wide Colour Enhancer Plus.
Football Mode
Feel like you're actually in the stadium cheering on your favourite team with Samsung's Football Mode. At the press of a button it optimises picture and sound settings for a better football viewing experience.
Freeview
Freeview is a free to air digital service built into your TV to offer more choice with free access to over 50 TV channels. So now there's always something to watch!
ConnectShare
ConnectShareTM 11 Movie lets you watch videos, play music or view photos from a USB connection without needing to use a PC. Simply plug your USB drive directly into your Samsung TV's USB port and watch on the big screen with friends and family. ConnectShareTM - 11 Supported formats include AVI, ASF, MP3, JPEG and others.
Slim Design
Samsung Slim Design. Encased in an attractive black edge frame combined with an appealing black rectangular stand, this beautifully designed TV will complement any room in your home.
2 x HDMI
2 x HDMI connections give you superior picture and sound from your HD source. The High-Definition Multimedia Interface (HDMI) is a digital connection that can transmit HD video and audio over a single cable. Use it to optimize the image quality when you connect your TV to high-definition sources such as an HD cable TV, satellite receiver, or Blu-ray player.
Samsung UE19H4000AW 4 Series - 19" LED TV
LED-backlit LCD TV
Diagonal Class
19"
Resolution
1366 x 768
Display Format
720p
Motion Enhancement Technology
100 Clear Motion Rate
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T
Multi-channel Preview
Picture-in-picture (PIP)
Speaker System
2 speakers
Sound Effects
DTS Studio Sound, DTS Premium Sound 5.1
USB Port
Yes , 1 ports
Remote Control
Standard remote
AC 230V ( 50/60 Hz )
Energy Class
Class A
32 Watt
Power Consumption (On mode)
17 W
Energy Consumption per Year
25 kWh
44.73 cm x 6.45 cm x 28.36 cm
2.45 kg
LED-backlit LCD TV
Energy Class
Class A
32 Watt
17 W
25 kWh
Diagonal Class
19"
Series
4 Series
TV Tuner
Video Interface
HDMI Ports Qty
2 ports
HDCP Compatible
Modes
Game mode, Football Mode Basic
Timer Functions
Sleep, wake
Dimensions
Without stand
44.73 cm
6.45 cm
28.36 cm
2.45 kg
Enclosure Colour
Display
Resolution
1366 x 768
Display Format
720p
LED backlight
HyperReal Engine, Wide Color Enhancer Plus, USB Cloning, E-Manual, Embeded POP
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T
Video Features
Teletext
Electronic Programme Guide
Digital EPG
Media Player
USB Port
Yes , 1 ports
Remote Control
Standard remote
Remote Control Model
Samsung TM1240A
Audio System
Digital Audio Format
DTS digital output, Dolby Digital Plus output, Dolby Pulse output
Surround Mode
Sound Effects
Speaker System
2 speakers
Output Power / Total
6 Watt
Down-firing Speaker, Auto Volume Leveller (AVL)
Speakers
2 x main channel speaker - built-in - 3 Watt
Driver Details
Main channel speaker: 1 x full-range driver
Network & Internet Multimedia
Connect & Share
ConnectShare Movie
Connector Type
2 x HDMI , Composite video / component video input , Digital audio output (optical) , USB 2.0 , SCART , Headphones , Audio input
Power supply
Nominal Voltage
Power Consumption Stand by
0.3 Watt
Auto On/Off
Dimensions & Weight Details
Panel without stand - 44.73 cm x 6.45 cm x 28.36 cm x 2.45 kg , Panel with stand - 44.73 cm x 15.18 cm x 31.86 cm x 2.6 kg
Width (Shipping)
62.3 cm
Depth (Shipping)
10.2 cm
Height (Shipping)
33.1 cm
Weight (Shipping)
3.3 kg
