Samsung's microSD PRO has added memory capacity and multi-device functionality so you can focus on life, not technology. This Class 10 SD card with U3 compatibility, is ideal for 4K UHD video recording & playback. And with fast read & write speeds of up to 90MB/s & 60MB/s respectively, you can also transfer files and shoot burst mode photos with minimal lag.
Fast read & write speeds
Samsung's microSD PRO has added memory capacity and multi-device functionality so you can focus on life, not technology. This Class 10 SD card with U3 compatibility, is ideal for 4K UHD video recording & playback. And with fast read & write speeds of up to 90MB/s & 60MB/s respectively, you can also transfer files and shoot burst mode photos with minimal lag. -
4K Ultra HD video
Capture the moments that matter. With the Samsung microSD PRO Card, you can shoot rich and detailed 4K UHD videos from your smartphone, tablet, or camera and be confident that each memory will be safe. Play your videos back on your 4K UHD TV or monitor and relive the experience as vividly as the day it happened. -
Waterproof
Samsung Memory Cards can survive up to 24 hours in seawater. -
Temperature-proof
These memory cards can endure temperatures from -25° to 85° Celsius. -
X-Ray-proof
The cards protect your precious data from damage caused by airport X-ray machines. -
Magnetic-proof
These memory cards can resist magnetic fields of up to 15,000 gauss - the equivalent of a high- field MRI scanner. -
Transfer faster
Transfer 660 photos per minute. With a transfer speed of up to 90 MB per second, you can spend less time transferring memories, and more time making them. -
A perfect partner
Get the most out of the latest 4K UHD video- enabled smartphones, tablets and action cameras. This memory card works with even the most advanced devices to protect your memories for life.
- Samsung Pro - flash memory card - 16 GB - microSDHC UHS-I
- Product Type
- Flash memory card
- Form Factor
- microSDHC UHS-I Memory Card
- Storage Capacity
- 16 GB
- Speed Rating
- UHS Class 3 / Class10
- Included Memory Adapter
- microSDHC to SD adapter
- 10 years warranty
- Product Type
- Flash memory card
- Storage Capacity
- 16 GB
- Speed Class
- Read Rate
- Up to 90 MB/s
- Write Rate
- Up to 60 MB/s
- Form Factor
- Magnetic-proof, waterproof, X-ray-proof, temperature-proof
- Limited warranty - 10 years
- 15 mm
- 11 mm
- Thickness
- 1 mm
- 0.5 g
- -25 °C
- 85 °C
- 0 - 93%
