Samsung 120GB 750 Evo Series SATA 6Gb/s 2.5" SSD
Quicklinx: BZ65WS00 Mfr#: MZ-750120BW
Enjoy superior computing for everyday use
The 750 EVO boasts a fast computing experience thanks to TurboWrite technology and RAPID mode. TurboWrite technology accelerates sequential write speeds by creating a write buffer inside the SSD. Magician software provides the option to enhance PC performance with RAPID mode, which processes data on a system level using unused PC memory (DRAM) as a cache.
Secure data through advanced data encryption
The 750 EVO features SED¹ technology to help keep your data safe. An AES-256-bit hardware-based full disk encryption engine secures your data with significantly less performance degradation often experienced with software-based encryption. And the 750 EVO is compliant with TCG™² Opal v2.0 standards and IEEE®³ 1667 protocol. ¹ Self-Encrypting Drive ² Trusted Computing Group ³ Institute of Electrical and Electronics Engineers.
Depend on solid reliability wherever life takes you
The flash-based 750 EVO provides superior resistance against shock and vibration for computing on the go. It also ensures 35 Total Bytes Written (TBW) for the 120 GB model and 70 TBW for the 250 GB model or up to 3 years.* * TBW or 3 years, whichever comes first.
Discover easy installation and SSD management
The 750 EVO comes with software to help entry-level users easily install and manage their SSDs. Samsung Data Migration software provides a powerful custom-cloning feature that ensures migration work even when the source data is greater than the SSD capacity. And Magician software simplifies SSD management, enabling even novices to maximise the performance and lifetime of the SSDs.
  • Heighten your computing experience with fast performance
    The Samsung 750 EVO SSD, with a SATA interface, is an outstanding high-performance choice for an enhanced everyday computing experience. With high sequential read and write speeds and exciting random read and write speeds, you will find yourself handling multitasking faster than before. The sequential write performance is measured under the TurboWrite mode.
  • Enjoy superior computing for everyday use
  • Secure data through advanced data encryption
    An AES-256-bit hardware-based full disk encryption engine secures your data with significantly less performance degradation often experienced with software-based encryption. And the 750 EVO is compliant with TCG Opal v2.0 standards and IEEE 1667 protocol.
Samsung 750 EVO MZ-750120 - SSD - 120 GB - SATA 6Gb/s
Solid state drive - internal
120 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Hardware Full Disk Encryption (FDE), TRIM support, DDR3 DRAM Cache, DevSleep mode, Auto Garbage Collection Algorithm, Worldwide Name (WWN), RAPID mode support, TurboWrite Technology, Samsung MGX Controller, S.M.A.R.T., 256-bit AES, IEEE 1667
69.85 mm x 100 mm x 6.8 mm
45 g
3-year warranty
120 GB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
Buffer Size
256 MB
69.85 mm
100 mm
6.8 mm
45 g
Performance
SSD Endurance
35 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 520 MBps (write)
Maximum 4KB Random Write
88000 IOPS
Maximum 4KB Random Read
94000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Software Included
Drivers & Utilities, Samsung Magician Software
Limited warranty - 3 years
70 °C
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
