Samsung's SM863 SSDs with 2-bit MLC V-NAND are an ideal storage solution for write-intensive applications such as mail servers, data warehousing and high performance computing, providing high endurance for around the clock operations.
- Samsung SM863 MZ-7KM1T9E - SSD - 1.92 TB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 1.92 TB
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- TRIM support, DRAM cache, End-to-end data protection, 3D V-NAND Technology, Dynamic Thermal Guard protection, Enterprise Power-Loss Protection, Enterprise, 24x7 availability, Advanced ECC Engine, Mercury controller, S.M.A.R.T.
- 7.01 cm x 10 cm
- 63.5 g
- 5-year warranty
- Capacity
- 1.92 TB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 7.01 cm
- 10 cm
- 63.5 g
Performance
- SSD Endurance
- 12320 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 520 MBps (read) / 485 MBps (write)
- 4KB Random Read
- 97000 IOPS
- 4KB Random Write
- 29000 IOPS
Reliability
- MTBF
- 2,000,000 hours
- 24x7 Operation
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 2.4 Watt (read) , 3.1 Watt (write)
- Limited warranty - 5 years
- 0 °C
- 70 °C
- 5 - 95% (non-condensing)
