Product
Brand
Sahara 10m Kit & Bulkheads
Quicklinx: B8F6WS00 Mfr#: 1770001H
Sahara Cable Kit with cables & bulkheads 10m WITH HDMI Sahara Reference: 1770001H Description
Standard cables supplied with the kit: 1xVGA cable, male to male 1x3.5mm stereo mini jack, male to male 3 x phono cables, yellow, red and white, male to male All other cables supplied as optional extras The ultimate plug and play cable kit from Sahara Kit includes surface mounted metal housing with removable face plate Housing is populated with VGA, 1 x 3.5mm mini jack, 3 x phono and 1 x USB gender changers which form the bulkheads Simply drop the terminated cables into the box from the top, sides or back. Connect to the bulkheads and run cables out of the projector giving 1 x PC connection with audio, video connection via 3 x phono and USB HDMI connector now available.
Metal housing has the capability to be further populated to give a miximum of:
2 x PC connection 1 x audio via 3.5mm mini jack 1 x video/audio connection via 3 x phono connectors 1 x USB connection (utilising cable from interactive whiteboard) 1 x HDMI connection 1 x monitor re-drive OR serial connection 1 x video connection via S-Video connector OR extra audio via 3.5mm mini jack 1 x network/RJ45 cabl
Sahara power / audio / video cable kit
Cable
Power / audio / video cable kit
Cable Type
Details
Included Qty x Type
VGA cable - 15 PIN HD D-Sub (HD-15) (male) to 15 PIN HD D-Sub (HD-15) (male) , Audio cable - mini-phone stereo 3.5 mm to mini-phone stereo 3.5 mm
