Your basket is empty
Ruckus ZoneFlex R310 Dual-Band 802.11ac Radio Access Point
Quicklinx: C0B8WS00 Mfr#: 901-R310-WW02
  • IEEE 802.11n
The Ruckus ZoneFlex R300 delivers high-performance and reliable 802.11n wireless networking at the industry's most affordable price point. Unlike any other 802.11n wireless solution in its class, the ZoneFlex R300 combines patented adaptive antenna technology and automatic interference mitigation to deliver consistent, predictable performance at extended ranges with up to an additional 4 dB of BeamFlex gain on top of the physical antenna gain and up to 10 dB of interference mitigation. Additional performance enhancements to signal gain can be attributed to the chip-based transmit beam forming capability adding 3 dB when associated to a compatible client.
Each ZoneFlex R300 integrates Ruckus-patented BeamFlex, a software-controlled, high gain antenna array that continually forms and directs each 802.11n packet over the best performing signal path. The ZoneFlex R300 automatically selects channels for highest throughput potential using Ruckus ChannelFly dynamic channel management, adapting to environmental changes. Once deployed, enterprises never have to worry about constant site surveys as the environment changes.
Ruckus ZoneFlex R300 - radio access point
Radio access point
External
Worldwide
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of clients: 100 , Simultaneous VoIP clients: 30
Power Over Ethernet (PoE) Supported
PoE
13.5 cm x 13.8 cm x 3 cm
220 g
Radio access point
13.5 cm
13.8 cm
3 cm
220 g
Worldwide
External
Wireless
Data Transfer Rate
1167 Mbps
Network / Transport Protocol
L2TP, PPPoE
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
Selectable Channels Qty
11
Status Indicators
Power, status
Routing, auto-sensing per device, DHCP support, NAT support, power over Ethernet (PoE), load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), manageable, wall mountable, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), RADIUS support, 2T2R MIMO technology, ceiling mountable, security lock slot (cable lock sold separately)
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPA-PSK
Authentication Method
RADIUS, LDAP, Active Directory
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.3ac, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna
Internal
Gain Level
3 dBi
1 x 1000Base-T (PoE) - RJ-45
RoHS, WEEE, EN 60601-1-2
PoE
7.8 Watt
Limited warranty - lifetime
15 - 95% (non-condensing)
