Product
Ring Video Doorbell- Venetian Bronze
Clearance!
Clearance
Last Few Remaining
Limited Time Offer
Quicklinx: CTNPWS00 Mfr#: 88RG002FC100
Colours:
Ring Video Doorbell
See, hear and speak to anyone at your door from your smartphone, tablet or PC. Works on every home - with or without a doorbell. Quick and easy self-install.
Answer the Door From Anywhere
Get instant alerts when visitors press your Doorbell or trigger the built-in motion sensors. Then use the free Ring app to see, hear and speak to guests from your smartphone, tablet or PC.
• Motion-activated alerts
• Crystal-clear 720HD video
• Two-way talk with noise cancellation
Never Miss a Visitor
Ring lets you customize your motion sensors, so you’ll always be the first to know when you have a visitor. With infrared night vision and a weather-resistant design, you can monitor your home around the clock – day or night, rain or shine.
• Custom motion zones
• Infrared night vision
• Lifetime purchase protection
Home Security at Your Fingertips
Power your Video Doorbell with its built-in rechargeable battery, or connect it to your existing doorbell wiring for a non-stop charge. It also comes with everything you need to install your Doorbell in just a few minutes, with no professional help required.
• Dual power options
• Simple installation and setup
• iOS, Android, Mac and Windows 10 compatible
A Ring of Security Around Your Home
With a Video Doorbell at your door and Stick Up Cams around the house, you can create a Ring of Security around your entire home, and get complete peace of mind for you and your family.
  • See, hear and speak to visitors
    With Ring, you can monitor your home from your smartphone, tablet or PC. Every Ring device features a wide-angle lens and a built-in microphone and speaker, so you can see, hear and speak to anyone on your property from anywhere.
  • Home security at your fingertips
    Ring's customizable motion sensors let you focus-in on the most important areas of your home. You'll get instant alerts as soon as Ring detects motion, so you'll always be the first to know when anyone steps foot on your property.
  • A ring of security around your home
    Ring lets you monitor every corner of your property. With a video doorbell at your door and stick up cams around the house, you can create a Ring of Security around your entire home.
Ring - doorbell
Doorbell
Sensor Type
Motion
Wireless - Wi-Fi
Venetian bronze
Doorbell
Sensor Type
Motion
Wireless - WiFi
Camera
Built-in microphone, built-in stereo speakers
Venetian bronze
Warranty
