Ring Video Doorbell - Satin Nickel
Quicklinx: D39MWS00 Mfr#: 8VR1S5-SEU0
Type: Doorbell camera
Compatible With: Alexa, IFTTT, SmartThings
Stock Status: In Stock, Used Stock
Colours:
13 in stock
£74.17 ex VAT
£89.00 inc VAT
Express delivery Order within the next 10 hours for delivery tomorrow
Ring Video Doorbell
See, hear and speak to anyone at your door from your smartphone, tablet or PC. Works on every home - with or without a doorbell. Quick and easy self-install.
Answer the Door From Anywhere
Get instant alerts when visitors press your Doorbell or trigger the built-in motion sensors. Then use the free Ring app to see, hear and speak to guests from your smartphone, tablet or PC.
• Motion-activated alerts
• Crystal-clear 720HD video
• Two-way talk with noise cancellation
Never Miss a Visitor
Ring lets you customize your motion sensors, so you’ll always be the first to know when you have a visitor. With infrared night vision and a weather-resistant design, you can monitor your home around the clock – day or night, rain or shine.
• Custom motion zones
• Infrared night vision
• Lifetime purchase protection
Home Security at Your Fingertips
Power your Video Doorbell with its built-in rechargeable battery, or connect it to your existing doorbell wiring for a non-stop charge. It also comes with everything you need to install your Doorbell in just a few minutes, with no professional help required.
• Dual power options
• Simple installation and setup
• iOS, Android, Mac and Windows 10 compatible
A Ring of Security Around Your Home
With a Video Doorbell at your door and Stick Up Cams around the house, you can create a Ring of Security around your entire home, and get complete peace of mind for you and your family.
Ring Protect Plans
Real-time Ring alerts, Real-time motion alerts, Custom motion detection, Two-way talk, Live View and Theft Protection are included as standard with all Ring products. All Ring products come with a 2 year warranty.
If you want to store, review, share and download videos from your events you will need to purchase a Ring Protect Plan, available from £2.50 per month. These are available from https://en-uk.ring.com/pages/protect-plans.
  • Answer the door from anywhere
  • Never miss a visitor
    Ring lets you customize your motion sensors, so you'll always be the first to know when you have a visitor. With infrared night vision and a weather-resistant design, you can monitor your home around the clock - day or night, rain or shine.
  • Home security at your fingertips
Ring Video Doorbell - doorbell camera
Doorbell camera
Functions
Motion detection, camera
Power Source
Hardwired, battery
Wireless - 802.11b/g/n
Frequency Band
2.4 Ghz
Supported Host Device OS
iOS, Android, Windows, MacOS
Camera
Audio - Day&Night
Satin nickel
2 year warranty
6.17 cm x 2.21 cm x 12.65 cm
Doorbell camera
Functions
Power Source
Hardwired, battery
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz
Apple MacOS, Android, Apple iOS, Windows 10
Weatherproof, instant alerts 720p resolution support
Camera
Day & Night Functionality
Audio Support
Video Modes
720p
Motion Detection Technology, 2-way voice communication, 180° field of view
Motion Sensor
Automatic night vision, custom motion zones
Satin nickel
Nominal Voltage
DC 8 - 24 V
Warranty
2 year warranty
6.17 cm
2.21 cm
12.65 cm
-20 °C
48 °C
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: D39M 041430
Condition: New item but packaging damaged
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £57.50
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Compatible With: IFTTT
Compatible With: SmartThings
Brand: Ring
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
