Ring Video Doorbell
See, hear and speak to anyone at your door from your smartphone, tablet or PC. Works on every home - with or without a doorbell. Quick and easy self-install.
Answer the Door From Anywhere
Get instant alerts when visitors press your Doorbell or trigger the built-in motion sensors. Then use the free Ring app to see, hear and speak to guests from your smartphone, tablet or PC.
• Motion-activated alerts
• Crystal-clear 720HD video
• Two-way talk with noise cancellation
Never Miss a Visitor
Ring lets you customize your motion sensors, so you’ll always be the first to know when you have a visitor. With infrared night vision and a weather-resistant design, you can monitor your home around the clock – day or night, rain or shine.
• Custom motion zones
• Infrared night vision
• Lifetime purchase protection
Home Security at Your Fingertips
Power your Video Doorbell with its built-in rechargeable battery, or connect it to your existing doorbell wiring for a non-stop charge. It also comes with everything you need to install your Doorbell in just a few minutes, with no professional help required.
• Dual power options
• Simple installation and setup
• iOS, Android, Mac and Windows 10 compatible
A Ring of Security Around Your Home
With a Video Doorbell at your door and Stick Up Cams around the house, you can create a Ring of Security around your entire home, and get complete peace of mind for you and your family.
Answer the door from anywhere
Get instant alerts when visitors press your Doorbell or trigger the built-in motion sensors. -
Never miss a visitor
Ring lets you customize your motion sensors, so you'll always be the first to know when you have a visitor. With infrared night vision and a weather-resistant design, you can monitor your home around the clock - day or night, rain or shine. -
Home security at your fingertips
- Ring Video Doorbell - IP intercom station - 802.11b/g/n - antique brass
- Product Type
- Functions
- Motion detection, camera
- Power Source
- Hardwired, battery
- Connectivity
- Wireless - 802.11b/g/n
- Frequency Band
- 2.4 Ghz
- Supported Host Device OS
- iOS, Android
- Camera
- Audio - Day&Night
- Antique brass
- Image Colour Disclaimer
- The displayed product image may be a different colour
- 1-year warranty
- 6.17 cm x 2.21 cm x 12.65 cm
- Product Type
- Functions
- Power Source
- Connectivity Technology
- Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 Ghz
- iOS, Android
- Weatherproof 720p resolution support
Camera
- Day & Night Functionality
- Audio Support
- Video Modes
- 720p
- 2-way voice communication
Motion Sensor
- Automatic night vision
- Antique brass
- Warranty
- 1-year warranty
- 6.17 cm
- 2.21 cm
- 12.65 cm
- -20 °C
- 48 °C
