Stick Up Cam
Goes everywhere. Sees everything.
Wired indoor/outdoor HD camera with two-way talk and versatile mounting options. Power through plug-in or Power over Ethernet. Connectivity via Wi-Fi or Ethernet.
- 1080p HD Video
- Two-Way Talk
- Indoor/Outdoor
- Motion-Activated Notifications
- Siren
Home at your fingertips. Anytime you need it.
Always know who’s at home with mobile notifications and Live View. See, hear and speak to people and pets with HD video and two-way talk. And sync all your Ring devices to the app to control your entire home security with one simple dashboard. Compatible with iOS, Android and Mac devices.
Nonstop power. Endless options.
Place it inside or out. On a wall or flat surface. With Power over Ethernet or Micro USB. We give you all the options, so you can protect what’s important on your own terms.
Smart security. Simple setup.
Get everything you need to setup your device in minutes with the included toolkit. Then use the adjustable mounting bracket to find your ideal setting.
Customise your coverage with motion zones.
Create and customise up to three motion zones to protect specific areas of your home. Then set your own motion schedules so you only get notifications when you need them.
'Alexa, show me my Stick Up Cam.’
Get smart security at the sound of your voice, and combine Stick Up Cam with select Alexa devices to launch real-time video from the comfort of your couch. Want to see who’s there? Just ask Alexa.
Ring Protect Plans
Real-time Ring alerts, Real-time motion alerts, Custom motion detection, Two-way talk, Live View and Theft Protection are included as standard with all Ring products. All Ring products come with a 2 year warranty.
If you want to store, review, share and download videos from your events you will need to purchase a Ring Protect Plan, available from £2.50 per month. These are available from https://en-uk.ring.com/pages/protect-plans.
Always know who's at home with mobile notifications and Live View. See, hear and speak to people and pets with HD video and two-way talk. And sync all your Ring devices to the app to control your entire home security with one simple dashboard. -
Nonstop power, endless options
Place it inside or out. On a wall or flat surface. With Power over Ethernet or Micro USB. You have all the options, so you can protect what's important on your own terms. -
Smart security, simple setup
Get everything you need to setup your device in minutes with the included toolkit. Then use the adjustable mounting bracket to find your ideal setting. -
Customize your coverage with motion zones
Create and customize up to three motion zones to protect specific areas of your home. Then set your own motion schedules so you only get notifications when you need them.
- Ring Stick Up Cam Wired - network surveillance camera
- Network surveillance camera - fixed - outdoor, indoor - weatherproof
- Audio
- Yes: two-way audio capability
- Camera Mount Type
- Wall mount, ceiling mount
- 6 cm x 6 cm x 9.7 cm
- White
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Motion Detection
- Video Modes
- 1080p
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a
- Cables Included
- 1 - micro-USB cable - external
- Motion sensor
- 2 year warranty
- Environmental Parameters (operating)
- -20.5 °C - 48.5 °C
- Audio Support
- Camera Mount Type
- Wired, wireless
- 6 cm
- 6 cm
- 9.7 cm
Camera
- Colour - Day&Night - fixed - outdoor, indoor - weatherproof
- Motion Detection
- Video Modes
- 1080p
- Motion sensor
Lens Construction
- Horizontal Field of View (degree)
- 150
- Vertical Field of View (degree)
- 85
- Network Interface
- Ports
- LAN/power
- Included Accessories
- Base cover, 2 power adapters, security sticker, base pad
- Cables Included
- 1 x micro-USB cable - external
- White
- Limited warranty - 2 year
- -20.5 °C
- 48.5 °C
