Add security anywhere – inside or out – with the versatile Stick Up Cam Battery. Its wire-free design means you can put it where you need it and move it when you need to. Place it on a flat surface for flexibility or mount it to a wall for a more permanent solution. With Stick Up Cam Battery, you’ll always be connected to home so you can see what’s happening at anytime.
- Ring Stick Up Cam Battery - network surveillance camera
- Network surveillance camera - fixed - outdoor, indoor - weatherproof
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- Camera Mount Type
- Surface mount, wall mount
- 5.99 cm x 5.99 cm x 9.7 cm
- 154 g
- Black
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Motion Detection
- Video Modes
- 1080p
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Intelligent Assistant
- Alexa
- Cables Included
- 1 - micro-USB charge cable - external
- Smartphone Monitoring
- 1-year warranty
- Environmental Parameters (operating)
- -20 °C - 50 °C
- Audio Support
- Camera Mount Type
- Wireless
- 5.99 cm
- 5.99 cm
- 9.7 cm
- 154 g
Camera
- Colour - Day&Night - fixed - outdoor, indoor - weatherproof
- Motion Detection
- Video Modes
- 1080p
- Digital Video Capture Resolution
- 1920 x 1080
Lens Construction
- Horizontal Field of View (degree)
- 110
- Vertical Field of View (degree)
- 57
- Diagonal Field of View (degree)
- 130
- Network Interface
- Included Accessories
- Mounting kit, rechargeable battery, security sticker
- Cables Included
- 1 x micro-USB charge cable - external
- Black
- Battery
- 1
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Alexa
- Limited warranty - 1 year
- -20 °C
- 50 °C
