Ring Spotlight Solar Panel - White
Quicklinx: DMWBWS00 Mfr#: 8ASPS7-WEU0
Non-Stop Power for Spotlight Cam
Connects to Spotlight Cam Battery for a continuous charge, so you’ll never run out of power.
A few hours of sunlight every day will keep your Spotlight Cam Battery charged around the clock, so you’ll never run out of power. With an included toolkit and cable, you’ll be set up in just a few minutes.
  • Weather-resistant design
  • Adjustable mounting bracket
  • Only works with Spotlight Cam Battery
Ring solar charger
Solar charger
White
Solar charger
Enclosure Colour
White
