Connect Solar Panel to Stick Up Cam to get non-stop power, and you’ll never need to charge your battery.
- Ring - solar panel - 2 Watt
- Solar panel - external
- Output Voltage
- 5 V
- Power Capacity
- 2 Watt
- Included Accessories
- Screwdriver, mounting bracket, drill bit
- Black
- 13.97 cm x 1.27 cm x 19.68 cm
- 1-year warranty
- Black
- Output Voltage
- 5 V
- Power Capacity
- 2 Watt
- Cables Included
- Micro-USB cable 3 m
- Weather-resistant
- Limited warranty - 1 year
- -28 °C
- 48 °C
- 13.97 cm
- 1.27 cm
- 19.68 cm
