Ring All-new Stick Up Cam Battery
Quicklinx: FGDKWS00 Mfr#: 8SC1S9-WEU0
Compatible With: Alexa
Select:
£74.17 ex VAT
£89.00 inc VAT
Express delivery Delivered on Tuesday
Add security anywhere – inside or out – with the versatile Stick Up Cam Battery. Its wire-free design means you can put it where you need it and move it when you need to. Place it on a flat surface for flexibility or mount it to a wall for a more permanent solution. With Stick Up Cam Battery, you’ll always be connected to home so you can see what’s happening at anytime.
Ring Stick Up Cam Battery - 3rd Generation - network surveillance camera
Network surveillance camera - fixed - outdoor, indoor - weatherproof
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
Camera Mount Type
Wall mount, ceiling mount
5.99 cm x 5.99 cm x 9.7 cm
White
Wireless
Camera
Colour - Day&Night
Motion Detection
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Intelligent Assistant
Alexa
1 - micro-USB charge cable - external
Smartphone Monitoring
1-year warranty
Environmental Parameters (operating)
-20.5 °C - 48.5 °C
Audio Support
Camera Mount Type
Wireless
5.99 cm
5.99 cm
9.7 cm
Europe
Camera
Colour - Day&Night - fixed - outdoor, indoor - weatherproof
Motion Detection
Video Modes
1080p
Digital Video Capture Resolution
1920 x 1080
Lens Construction
Horizontal Field of View (degree)
116
Vertical Field of View (degree)
65
Network Interface
Mounting kit, base cover, rechargeable battery, security sticker, base pad
1 x micro-USB charge cable - external
White
1
Android 5.0 or later, Apple iOS 9.1 or later
Internet of Things (IoT)
Intelligent Assistant Compatible
Alexa
Limited warranty - 1 year
-20.5 °C
48.5 °C
Brand: Ring
Price Range Ex VAT: 50 - 100
