The SP C342DN A4 colour printer is smart and easy to use, and its exceptional efficiency makes it ideal for almost any small to medium sized office and business branch. Usability is enhanced by the intuitive, icon-based 4.3 inch touch panel that has similar functional design characteristics as Ricoh's MFPs for easy integration. Jobs can be printed quickly, securely and simply from mobile phones, and workflow is also accelerated by the high-speed Intel processor. All this is combined with low operating costs, so it's very economic too
Intuitive 4.3 inch colour touch panel
Compact body and front operation
- High-speed processor accelerates large print jobs
A touch more useful - and faster
The 4.3-inch touch panel provides great usability through an intuitive, easy-to-operate interface: the panel is icon-based and readily allows the addition of shortcuts. Speed up the workflow - the driver remembers your often used print settings, which adds to its superb usability. -
High productivity, low print costs
No matter, what industry you're working in, you will benefit from the productivity and low costs, offered by the SP C342DN. Among many advantages, its rapid processor enables the processing of heavy jobs more quickly, and peak volumes per month are well within its capabilities. Heightened productivity is complemented by highly competitive operating costs.
- Ricoh SP C342DN - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 29 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 25 ppm - B/W - A4 (210 x 297 mm) , Up to 25 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- Processor
- Intel Atom 1.46 GHz
- RAM Installed (Max)
- 2 GB
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PDF
- Media Type
- Envelopes, plain paper, recycled paper, thick paper, thin paper, middle thick paper, label paper, preprinted paper, coated paper, glossy paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 500-sheet input tray, 100-sheet bypass tray
- Monthly Duty Cycle (max)
- 75000 pages
- Networking
- Print server
- System Requirements
- HP-UX 11.x, Apple MacOS 8.6 or later, HP-UX 11i v2, SCO OpenServer 5.0.7, SunSoft Solaris 2.9, Red Hat Enterprise Linux 4, SCO OpenServer 6, SunSoft Solaris 2.10, IBM AIX 5L 5.3, Microsoft Windows Server 2008 R2, HP-UX 11i v3, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Enterprise Linux 6, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, IBM AIX 5L 6.1, IBM AIX 5L 7.1, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
- 40 cm x 48 cm x 40.4 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- 4.3 inch LCD touch screen
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- Direct Printing Specifications
- PictBridge
- PostScript Support
- Standard
- First Print Out Time B/W
- 13.5 sec
- First Print Out Time Colour
- 13.5 sec
- Fonts Included
- 45 x PCL , 13 x Intellifonts , 136 x PostScript 3
- Media Handling
- Processor
RAM
- 2 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm), Foolscap (216 x 343 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Max Media Capacity
- 1100 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 75000 pages
- Networking
- Print server
- Connections
- 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 2800 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 2800 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 2800 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 2800 pages ISO/IEC 19798
- ISO 9001, ISO 14001, ISO 27001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 1.3 kW
- Power Consumption Sleep
- 0.5 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- 40 cm
- 48 cm
- 40.4 cm
- 29 kg
