Product
Ricoh SPC342DN A4 Colour Laser Printer
Quicklinx: CD03WS00 Mfr#: 916937
The SP C342DN A4 colour printer is smart and easy to use, and its exceptional efficiency makes it ideal for almost any small to medium sized office and business branch. Usability is enhanced by the intuitive, icon-based 4.3 inch touch panel that has similar functional design characteristics as Ricoh's MFPs for easy integration. Jobs can be printed quickly, securely and simply from mobile phones, and workflow is also accelerated by the high-speed Intel processor. All this is combined with low operating costs, so it's very economic too
  • Intuitive 4.3 inch colour touch panel
  • Compact body and front operation
  • High-speed processor accelerates large print jobs
  • A touch more useful - and faster
    The 4.3-inch touch panel provides great usability through an intuitive, easy-to-operate interface: the panel is icon-based and readily allows the addition of shortcuts. Speed up the workflow - the driver remembers your often used print settings, which adds to its superb usability.
  • High productivity, low print costs
    No matter, what industry you're working in, you will benefit from the productivity and low costs, offered by the SP C342DN. Among many advantages, its rapid processor enables the processing of heavy jobs more quickly, and peak volumes per month are well within its capabilities. Heightened productivity is complemented by highly competitive operating costs.
Ricoh SP C342DN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
Printer
Print Speed
Up to 25 ppm - B/W - A4 (210 x 297 mm) , Up to 25 ppm - colour - A4 (210 x 297 mm)
Built-in Devices
4.3 inch LCD touch screen
Wired
USB 2.0, Gigabit LAN, USB host
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Direct Printing Specifications
PictBridge
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
13.5 sec
First Print Out Time Colour
13.5 sec
Language Simulation
PCL 5C, PostScript 3, PCL 6, PDF
Fonts Included
45 x PCL , 13 x Intellifonts , 136 x PostScript 3
Media Handling
500-sheet input tray, 100-sheet bypass tray
Intel Atom 1.46 GHz
RAM
RAM Installed (Max)
2 GB
Media Handling
Media Type
Envelopes, plain paper, glossy paper, coated paper, recycled paper, thick paper, thin paper, middle thick paper, label paper, preprinted paper
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm), Foolscap (216 x 343 mm)
Media Weight
60 g/m² - 220 g/m²
Total Media Capacity
600 sheets
Media Feeders
1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Max Media Capacity
1100 sheets
Output Trays Capacity
150 sheets
Duty Cycle
Monthly Duty Cycle (max)
75000 pages
Print server
1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 2800 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 2800 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 2800 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 2800 pages ISO/IEC 19798
ISO 9001, ISO 14001, ISO 27001
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
1.3 kW
Power Consumption Sleep
0.5 Watt
HP-UX 11.x, Apple MacOS 8.6 or later, HP-UX 11i v2, SCO OpenServer 5.0.7, SunSoft Solaris 2.9, Red Hat Enterprise Linux 4, SCO OpenServer 6, SunSoft Solaris 2.10, IBM AIX 5L 5.3, Microsoft Windows Server 2008 R2, HP-UX 11i v3, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Enterprise Linux 6, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, IBM AIX 5L 6.1, IBM AIX 5L 7.1, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
Environmental Standards
ENERGY STAR
40 cm
48 cm
40.4 cm
29 kg
