Ricoh SPC340DN A4 Colour Laser
Quicklinx: CD01WS00 Mfr#: 916936
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired
Technology: Laser
£228.84 ex VAT
£274.60 inc VAT
A fast processing A4 colour printer, the SP C340DN model more than meets the demands of most small to medium sized offices. You'll appreciate the low start-up costs, as well as the ability to print much more quickly and efficiently - thanks to its high-speed processor. Workflow is maximised with innovations like WiFi Direct (optional) where you can print from smart devices without connecting to a network. And the range of paper capacity, handling options and fast network connection all add to its efficient productivity
  • High-speed processor - much quicker on large print jobs
  • Print eye catching colour banners of up to 1,260 mm in length
  • High paper capacity and 25ppm print speed
  • 1200 x 1200 dpi colour printing
  • User friendly, business environment enhancing
    With its front operation and four-line LCD panel, the SP C340DN is simple to operate and maintain, so you have an ideal workmate for almost any office or business environment. Unobtrusive and efficiently delivering high 1200 x 1200 dpi quality at low cost, this model can help virtually everyone be more productive with less effort.
  • More mobility, more connectivity
    The SP C340DN enables quick printing by making the optimal of mobile technology and it provides added. Added to this is the extra connectivity.
  • Work more efficiently
    Well suited to versatile and mobile environments, the SP C340DN also sets the standard for efficient working. It provides a large paper capacity, which enables fewer interruptions to your printing schedule. Additionally there's also the high-speed processor - for printing large files faster - and a Gigabit Ethernet adapter for quicker connection.
Ricoh SP C340DN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
29 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 25 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 25 ppm - colour duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
Intel Atom 1.46 GHz
RAM Installed (Max)
2 GB (2 GB)
Language Simulation
PCL 5C, PostScript 3, PCL 6, PDF
Media Type
Envelopes, plain paper, recycled paper, thick paper, thin paper, middle thick paper, label paper, preprinted paper, coated paper, glossy paper
Total Media Capacity
600 sheets
Media Handling
500-sheet input tray, 100-sheet bypass tray
Monthly Duty Cycle (max)
75000 pages
Print server
AC 230V
HP-UX 11.x, Apple MacOS 8.6 or later, HP-UX 11i v2, SCO OpenServer 5.0.7, SunSoft Solaris 2.9, Red Hat Enterprise Linux 4, SCO OpenServer 6, SunSoft Solaris 2.10, IBM AIX 5L 5.3, Microsoft Windows Server 2008 R2, HP-UX 11i v3, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Enterprise Linux 6, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, IBM AIX 5L 6.1, IBM AIX 5L 7.1, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
40 cm x 48 cm x 38.7 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 x 1200 dpi
1200 x 1200 dpi
Direct Printing Specifications
PictBridge
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
13.5 sec
First Print Out Time Colour
13.5 sec
Language Simulation
Fonts Included
45 x PCL , 13 x Intellifonts , 136 x PostScript 3
Media Handling
Intel Atom 1.46 GHz
RAM
RAM Installed (Max)
2 GB / 2 GB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm), Foolscap (216 x 343 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Max Media Capacity
1100 sheets
Output Trays Capacity
150 sheets
Duty Cycle
75000 pages
Print server
Security Protocols & Features
LDAP, 802.1x
1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 1500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 1500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 1500 pages ISO/IEC 19798
ISO 9001, ISO 14001, ISO 27001
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
1.3 kW
Power Consumption Sleep
0.5 Watt
Environmental Standards
ENERGY STAR
40 cm
48 cm
38.7 cm
29 kg
Type: Printer
Output Type: Colour
Technology: Laser
Max Print Speed: 25ppm
Max Paper Size: A4 (210 x 297 mm)
Brand: Ricoh
