With the printers you benefit from the same expertise. The space-saving Aficio SP C240DN is the neat solution to those wanting affordable hardware functions and market-leading image quality.
- Ricoh SP C240DN - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 23.8 kg
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Max Media Size (Custom)
- 210 mm x 297 mm
- Print Speed
- Up to 16 ppm - colour - A4 (210 x 297 mm) , Up to 16 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 2400 x 600 dpi
- Max Resolution (Colour)
- 2400 x 600 dpi
- Automatic Duplexing
- Interface
- USB, LAN, USB host
- Processor
- 220 MHz
- RAM Installed (Max)
- 64 MB
- Language Simulation
- Windows GDI driver
- Media Type
- Envelopes, plain paper, cards, bond paper, recycled paper, thick paper, thin paper, middle thick paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 30000 pages
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- Microsoft Windows Server 2003, Apple MacOS X 10.3 or later, Microsoft Windows Vista / XP / 7, Microsoft Windows Server 2008
- 40 cm x 45 cm x 32 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 2400 x 600 dpi
- 2400 x 600 dpi
- Direct Printing Specifications
- PictBridge
- First Print Out Time B/W
- 14 sec
- First Print Out Time Colour
- 14 sec
- Media Handling
- Processor
- 220 MHz
RAM
- 64 MB
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- 210 mm x 297 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
- Media Weight
- 60 g/m² - 160 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 160 g/m² , 1 x manual - 1 sheet - A4 (210 x 297 mm) weight: 60 g/m² - 160 g/m²
- Max Media Capacity
- 750 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 30000 pages
- Networking
- Print server
- Data Link Protocol
- TCP/IP, Bonjour
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 1.3 kW
- Power Consumption Stand by / Sleep
- 10 Watt
- OS Required
- 40 cm
- 45 cm
- 32 cm
- 23.8 kg
