Help your project teams work efficiently without sacrificing quality. The compact RICOH SP 6430DN prints up to 38 black-and-white pages per minute. Its space-saving LED print head technology produces eye-catching 1200x1200 dpi resolution images, and the low energy consumption and eco-features help to reduce your cost per page.
Keep projects on track
When you outsource print projects, you can't share information as quickly. Print both everyday office documents and special projects in-house with the compact, versatile RICOH SP 6430DN black-and-white printer. Show off all the fine print in CAD drawings, manufacturing designs, spreadsheets and floor plans with 1200x1200 dpi resolution. -
Place this printer nearly anywhere
Printing shouldn't take up too much time or space, and you'll give the SP 6430DN high marks on both counts. The printer fits on desktops, counters or cabinets - it's smaller than competitive laser printers thanks to LED print head technology. And, at 38 pages per minute, you can zip through jobs in no time. -
Ready, set, go - in under seven seconds
The longer you have to wait for a print job, the less time you have to work on the next project. With the SP 6430DN you can print your first document 6.5 seconds after warm-up. Adding toner or paper or clearing a misfeed is easy and fast, too, thanks to front-access design. -
Safeguard information at the printer
When you have extra layers of protection, you can feel better about sharing sensitive information like personnel records or financial information. The USB Device Server option allows you to use a different IP address to connect the SP 6430DN to a second locked network to help shield information from the internet or other security threats.
- Ricoh SP 6430DN - printer - B/W - LED
- Printer Type
- Workgroup printer - LED - B/W
- 21 kg
- Media Size Class
- Ledger
- Max Media Size
- A3 (297 x 420 mm)
- Min Media Size (Custom)
- 60 mm x 127 mm
- Max Media Size (Custom)
- 279 mm x 1260 mm
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- Processor
- 533 MHz
- RAM Installed (Max)
- 512 MB (1 GB)
- Card Reader
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PDF
- Media Type
- Envelopes, transparencies, labels, plain paper, recycled paper, thick paper, thin paper, postcards
- Total Media Capacity
- 600 sheets
- Media Handling
- 500-sheet input tray, 100-sheet bypass tray
- Monthly Duty Cycle (max)
- 150000 pages
- Networking
- Print server
- System Requirements
- UNIX, Linux, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2003 R2, Citrix Presentation Server 4.5, Citrix Presentation Server 4.0, Citrix XenApp 5, Citrix XenApp 6, Citrix XenApp 6.5, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1
- 45.9 cm x 39.2 cm x 34.75 cm
- Printer Type
- Workgroup printer - LED - monochrome
Printer
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.5 sec
- Media Handling
- Processor
- 533 MHz
RAM
- 512 MB / 1 GB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Media Handling
- Media Type
- Media Size Class
- Ledger
- Max Media Size
- A3 (297 x 420 mm)
- 60 mm x 127 mm
- 279 mm x 1260 mm
- Media Weight
- 52 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 500 rolls - 297 x 432 mm weight: 52 g/m² - 220 g/m² , 1 x manual - 100 sheets - 297 x 1260 mm weight: 52 g/m² - 220 g/m²
- Max Media Capacity
- 2100 sheets
Duty Cycle
- 150000 pages
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A
- Power Device
- Power supply - internal
- Frequency Required
- 60 Hz
- 554 Watt
- Power Consumption Sleep
- 0.45 Watt
- Software Included
- Web Image Monitor, Printer Driver Packager NX, @Remote, Device Manager NX
- OS Required
Environmental Standards
- ENERGY STAR
- 45.9 cm
- 39.2 cm
- 34.75 cm
- 21 kg
