Your basket is empty
Ricoh SP6430DN A3 Mono Laser Printer
Quicklinx: CDD6WS00 Mfr#: 906916
Help your project teams work efficiently without sacrificing quality. The compact RICOH SP 6430DN prints up to 38 black-and-white pages per minute. Its space-saving LED print head technology produces eye-catching 1200x1200 dpi resolution images, and the low energy consumption and eco-features help to reduce your cost per page.
Ricoh SP 6430DN - printer - monochrome - LED
Printer Type
Workgroup printer - LED - monochrome
21 kg
Media Size Class
Ledger
Max Media Size
A3 (297 x 420 mm)
Min Media Size (Custom)
60 mm x 127 mm
Max Media Size (Custom)
279 mm x 1260 mm
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
533 MHz
RAM Installed (Max)
512 MB (1024 MB)
Card Reader
Language Simulation
PCL 5E, PostScript 3, PCL 6, PDF
Media Type
Envelopes, transparencies, labels, plain paper, recycled paper, thick paper, thin paper, postcards
Total Media Capacity
600 sheets
Media Handling
500-sheet input tray, 100-sheet bypass tray
Monthly Duty Cycle (max)
150000 pages
Print server
AC 120 V
UNIX, Linux, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2003 R2, Citrix Presentation Server 4.5, Citrix Presentation Server 4.0, Citrix XenApp 5, Citrix XenApp 6, Citrix XenApp 6.5, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1
45.9 cm x 39.2 cm x 34.75 cm
Printer Type
Printer
Built-in Devices
Status LCD
Wired
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.5 sec
Language Simulation
Media Handling
533 MHz
RAM
RAM Installed (Max)
512 MB / 1024 MB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Media Handling
Media Type
Media Size Class
Ledger
Max Media Size
A3 (297 x 420 mm)
60 mm x 127 mm
279 mm x 1260 mm
Media Weight
52 g/m² - 220 g/m²
600 sheets
Media Feeders
1 x automatic - 500 rolls - 297 x 432 mm weight: 52 g/m² - 220 g/m² , 1 x manual - 100 sheets - 297 x 1260 mm weight: 52 g/m² - 220 g/m²
Max Media Capacity
2100 sheets
Duty Cycle
150000 pages
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A
Power supply - internal
AC 120 V
Frequency Required
60 Hz
554 Watt
Power Consumption Sleep
0.45 Watt
Software Included
Web Image Monitor, Printer Driver Packager NX, @Remote, Device Manager NX
Environmental Standards
ENERGY STAR
45.9 cm
39.2 cm
34.75 cm
21 kg
