Product
Brand
Ricoh SP C830DN A3 Colour Laser Printer
Quicklinx: CM3PWS00 Mfr#: 908697
Fast and efficient colour laser printers
The SP C830DN/SP C831DN are fast, user-friendly, colour A3 laser printers that are ideal in a busy office environment. They are easy to operate via a large 4.3-inch colour touch panel. Heavyweight paper up to 300 g/m² is handled in a particularly smooth and reliable way. Powered by Ricoh’s next-generation controller (GWNX), they give you outstanding security, a low Total Electricity Consumption, and comprehensive device management capabilities.
45/55 A4 pages per minute.
IC card authentication for increased security.
Attractively designed.
ECO Night Sensor reduces electricity consumption.
Center machine for multiple users.
All-round usability for all-round productivity.
Easy operation
Operating the SP C830DN/SP C831DN is extremely straightforward, thanks to a 4.3-inch colour touch panel with a large display and animated menus. Touching the home button quickly returns you to the home screen. Further time-saving functions include auto job reset, cancel, and an option for high-volume printing.
Office convenience
Create great-looking documents quickly and with minimal effort by using value-added finishing options such as a 2,000-sheet booklet finisher, 3,000-sheet finisher, punch unit and output jogger unit. Organise multiple jobs efficiently and enable users to effortlessly retrieve their documents by printing to the 4-bin mailbox.
Extensive paper handling capabilities
The Aficio™SP C830DN/SP C831DN handle paper between 52 and 300 g/m² (from the bypass tray). The two standard trays each take 550 sheets, the bypass tray 100 sheets, and the two optional trays a further 3,200 sheets, making a huge total capacity of 4,400 sheets. Paper sizes include A3, A4, A5, B4, B5, foolscap, government, folio, quarto, legal and executive, ensuring that these devices meet all your printing needs.
Innovative technologies
ECO Night Sensor
The innovative ECO Night Sensor further reduces the already low electricity consumption of these devices. The SP C830DN/SP C831DN can be set so that the main power shuts down when the light levels in the room dip below a certain level. The sensor detects both the decline of natural and artificial light. You can set the sensor to activate between 1 and 120 minutes after darkness falls.
Enhanced controller
Ease of use, time savings and increased productivity are ensured by the high-performance Ricoh GWNX controller, which allows you to configure device settings, monitor status, and create reports of usage.
New fusing system
Enjoy ecological benefits and print quality improvements thanks to Ricohs Quick Start Up Direct Heating (QSU-DH) fusing system. The device has a thin fusing belt around the heater, which reduces electricity consumption and shortens recovery time. Furthermore, fusing is done on a plane surface, reducing damage or wrinkles to papers. This leads to particularly high-quality envelope printing.
A complete print solution
Confidentiality ensured
Prevent potential information leaks, should a printout be forgotten to be picked up or picked up by mistake by restricting the use of the SP C830DN/SP C831DN to holders of a card with an Integrated Chip (IC). IC card authentication also reduces paper output by enabling you to choose the jobs you want to print.
Save colour print costs
Printing colour documents with ECOnomy Color significantly reduces the cost compared to full colour printing. This feature divides the print data into four parts: text, images, paints and lines. Text is printed at normal thickness; the thickness of images is reduced by half; and the thickness of paints and lines is reduced by 30%. Unlike the Draft mode available with similar technologies, ECOnomy Color produces prints with clear and impeccable text quality at all times.
Reduce your eco footprint
At Ricoh we help you lower your environmental footprint. The SP C830DN/SP C831DN have eco-friendly features such as sleep mode, duplex printing, ECO Night Sensor, and an on/off timer. Total Electricity Consumption (TEC) values are very low. In addition, these environmentally responsible printers are Energy Star compliant. This means less CO2 is produced in providing the energy needed to run them.
Keeping your workflow fluent
Innovative design
The SP C830DN/SP C831DN are attractively styled. Dark grey is used for the operational parts that are frequently used. These include the operation panel, top board and inner tray. A simple cube design enables these devices to fit flexibly into tight office spaces.
High productivity
The SP C830DN has a warm-up time of less than 29 seconds and prints 45 A4 pages per minute. Its first print is available after 3.7 seconds (B/ W) or 5.7 seconds (colour). The SP C831DN’s warm-up time is less than 25 seconds and it prints 55 A4 pages per minute. Its first print is produced after 3.4 seconds (B/W) or 5.1 seconds (colour).
Flexible printing
A USB/SD slot enables casual users to print easily from flash drives and memory cards. Enhancements to this capability increase the media print function, enabling a preview screen before printing; a greater number of available print settings; and multiple selection of PDF or TIFF files.
Critical capabilities for business communications
1 Easy access & intuitive operation via 4.3-inch colour touch panel.
2 USB/SD slot to enable easy printing from flash drives and memory cards.
3 4-bin mailbox for easy separation and collection of prints.
4 Standard 2x 550-sheet paper trays to stay productive at all times.
5 Standard 100-sheet bypass tray to take advantage of a wide range of paper sizes and types.
6 Optional 2 x 550-sheet paper trays or 2x 1,000- sheet large capacity tray for a choice of multiple paper sources.
7 1,200-sheet side large capacity tray to increase your productivity.
8 2,000-sheet booklet finisher, 3,000-sheet finisher & several punch kits for an entire range of finishing possibilities.
Ricoh SP C830DN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
97 kg
Media Size Class
A3/Ledger
Max Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm)
Print Speed
Up to 45 ppm - colour - A4 (210 x 297 mm) , Up to 45 ppm - B/W - A4 (210 x 297 mm) , Up to 45 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 45 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 dpi
Max Resolution (Colour)
1200 dpi
Automatic Duplexing
USB 2.0, LAN, USB 2.0 host
Intel Celeron M 600 MHz
RAM Installed (Max)
512 MB (1.5 GB)
Card Reader
Language Simulation
PCL 5C, PostScript 3, PCL 6, PDF
Media Type
Envelopes, transparencies, labels, plain paper, cards, bond paper, recycled paper
Total Media Capacity
1200 sheets
Media Handling
2x 550-sheet input trays, 100-sheet bypass tray
Monthly Duty Cycle (max)
200000 pages
Print server
AC 230V
SunSoft Solaris 2.6, SunSoft Solaris 7, HP-UX 10.x, HP-UX 11.x, SunSoft Solaris 8, SCO OpenServer 5.0.6, SunSoft Solaris 9, HP-UX 11i v2, SCO OpenServer 5.0.7, Microsoft Windows Server 2003, Novell NetWare 6.5, SunSoft Solaris 10, Red Hat Enterprise Linux 4, Apple MacOS X 10.4 or later, SCO OpenServer 6, IBM AIX 5L 5.3, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7, HP-UX 11i v3, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, IBM AIX 6.1, Red Hat Enterprise Linux 6, IBM AIX 7.1
Environmental Standards
EPEAT Gold
1 year warranty
67 cm x 68.4 cm x 64 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 dpi
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
3.7 sec
First Print Out Time Colour
5.7 sec
Language Simulation
Fonts Included
45 x TrueType , 13 x Intellifonts , 136 x PostScript 3
Media Handling
RAM
RAM Installed (Max)
512 MB / 1.5 GB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Media Handling
Media Type
Media Size Class
A3/Ledger
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), ANSI B (Ledger) (279 x 432 mm), A7 (74 x 105 mm)
Media Weight
52 g/m² - 300 g/m²
1200 sheets
Media Feeders
2 x automatic - 550 sheets - A3 (297 x 420 mm) weight: 52 g/m² - 256 g/m² , 1 x automatic - 100 sheets - A3 (297 x 420 mm) weight: 52 g/m² - 300 g/m²
Max Media Capacity
4400 sheets
Output Trays Capacity
500 sheets
Duty Cycle
200000 pages
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
1700 Watt
Power Consumption Stand by
81 Watt
Power Consumption Sleep
1.6 Watt
EPEAT Compliant
EPEAT Gold
ENERGY STAR
Limited warranty - 1 year
67 cm
68.4 cm
64 cm
97 kg
