Product
Brand
Ricoh SP C252sf Colour Laser Multifunction Printer
Quicklinx: 9H40WS00 Mfr#: 901633
The Ricoh SP C252SF color laser MFP offers standard wireless printing and mobile printing capabilities so you can access information where you need it, when you need it. Need to share documents quickly with coworkers and customers? The SP C252SF offers print/scan/copy/fax functionality plus cost-free document distribution capabilities with scan-to-email/FTP/folder and more. Tight on space? The SP C252SF is small enough to fit in cramped spaces, making it convenient for smaller offices. You can even include it as part of a Ricoh managed document services (MDS) strategy and measure how much time and money the SP C252DN can save for your organization.
Ricoh SP C252SF - multifunction printer (colour)
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
65000 pages
Max Copying Speed
Up to 20 ppm (mono) / up to 20 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 200 dpi, 200 x 100 dpi
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
90 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, card stock
Standard Media Capacity
250 sheets
Max Media Capacity
750 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
Office Machine Features
Save to USB flash drive, Internet faxing, scan to e-mail, scan to folder, scan to network, Locked Print Technology
AC 230 V (50/60Hz)
42 cm x 49.3 cm x 46 cm
29 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - colour
65000 pages
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Preset Enlargements
129%, 155%, 200%, 400%
Preset Reductions
50%, 65%, 78%, 93%
Maximum Copies
99
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, Sort, photo mode
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c
Automatic Duplexing
First Print Out Time B/W
14 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Transmission Memory Capacity
Up to 100 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
20 station(s)
Speed Dialing
200 station(s)
Broadcast Transmission
100 stations
Automatic redialing, smoothing, answering machine interface, one-touch speed dialling
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
90 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
160 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), 140 x 216 mm, JIS B5 (182 x 257 mm), 90 x 148 mm, JIS B6 (128 x 182 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
Max Media Capacity
750 sheets
1 sheet
150 sheets
Input tray - 250 sheets size: 90 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 160 g/m² , Output tray - 150 sheets - Legal (216 x 356 mm) , ADF - 35 sheets - Legal (216 x 356 mm) , Bypass tray - 1 sheet size: 90 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 160 g/m²
Speed Details
Printing: up to 20 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - colour , Printing: up to 21 ppm (Letter A) - B/W , Printing: up to 21 ppm (Letter A) - colour , Printing: up to 12 ppm (Letter A) - B/W duplex , Printing: up to 12 ppm (Letter A) - colour duplex , Copying: up to 20 ipm - B/W , Copying: up to 20 ipm - colour , Copying: up to 12 ipm - B/W duplex , Copying: up to 12 ipm - colour duplex , Scanning: up to 12 ppm - B/W , Scanning: up to 6 ppm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, Apple Mac OS X 10.3 - 10.6, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 R2
Software Included
Drivers & Utilities, Presto! PageManager
AC 230 V (50/60Hz)
1300 Watt
Power Consumption Standby
2.4 Watt
Direct Printing Specifications
PictBridge
Warm-Up Time
30 sec
First Copy Out Time B/W
20 sec
First Copy Out Time Colour
20 sec
Consumables Included
1 x Cartridge (black) - up to 1000 pages , 1 x Cartridge (yellow) - up to 1000 pages , 1 x Cartridge (magenta) - up to 1000 pages , 1 x Cartridge (cyan) - up to 1000 pages
cUL, UL 60950-1 Second Edition, CAN/CSA C22.2 No. 60950-1
ENERGY STAR Certified
42 cm
49.3 cm
46 cm
29 kg
