Your basket is empty
Ricoh SP C250sf Colour Laser Multifunction Printer
Quicklinx: 9H3YWS00 Mfr#: SPC250SFPROMO-BUNDLE
You can't always predict where your workday will take you. But you can be prepared for anything, anywhere. The compact RICOH SP C250SF color laser MFP offers high-quality print/scan/copy/fax capabilities for small offices and workgroups and helps you get the information you need, when you need it. With the constant hustle and bustle of buzzing work environments, the SP C250SF helps you meet everyday workflow demands with a host of productivity-enhancing features and produces documents in vibrant color for lasting impact. Is your smartphone or tablet nearby? Simply download the Ricoh smart device print and scan app to print to the SP C250SF directly from your personal mobile device. Designed with user-friendly controls to simplify administrative tasks in any environment, this multifunction system offers all-in-one performance to complete more jobs in less time and fits virtually any workspace - including desktops, retail counters and executive offices.
Ricoh SP C250SF - multifunction printer (colour)
Fax / copier / printer / scanner
Fax Type
G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
30000 pages
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 20 ppm (mono) / up to 20 ppm (colour)
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 100 dpi
Scanning
1200 x 1200 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Media Size
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, card stock
Standard Media Capacity
251 sheets
Max Media Capacity
751 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n), USB host
Office Machine Features
Scan to e-mail, scan to folder
AC 230 V (50/60Hz)
42 cm x 49.3 cm x 46 cm
29 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, EPEAT Silver
Fax Type
Plain paper
Printing Technology
Laser - colour
30000 pages
PC Connection
Standard Memory
256 MB
Copying
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c
Automatic Duplexing
First Print Out Time B/W
14 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Fax Machine
Compatibility
G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
200 x 100 dpi
Fax Machine Features
Fax memory backup
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
160 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
251 sheets
Max Media Capacity
751 sheets
150 sheets
Input tray - 251 sheets size: B6 (125 x 176 mm) - A4 (210 x 297 mm) weight: 60 g/m² - 160 g/m² , Output tray - 150 sheets size: B5 (176 x 250 mm) - A4 (210 x 297 mm) weight: 60 g/m² - 160 g/m² , ADF weight: 60 g/m² - 90 g/m²
Speed Details
Printing: up to 20 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - colour , Copying: up to 20 ipm - B/W , Copying: up to 20 ipm - colour
1 x USB 2.0 , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
Apple Bonjour
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Apple Mac OS X 10.6 or later
AC 230 V (50/60Hz)
1300 Watt
Direct Printing Specifications
PictBridge
Warm-Up Time
30 sec
Consumables Included
1 x Cartridge (black) - up to 1000 pages , 1 x Cartridge (yellow) - up to 1000 pages , 1 x Cartridge (cyan) - up to 1000 pages , 1 x Cartridge (magenta) - up to 1000 pages
cUL, UL 60950-1 Second Edition, CAN/CSA C22.2 No. 60950-1
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
42 cm
49.3 cm
46 cm
29 kg
