Where space is at a premium, the compact A4 black and white multifunctional printers, the Aficio SP 5200s is ideal. It delivers 4-in-1 printing, copying, and color scanning and faxing to meet all your document needs. Packed with features usually expected only from larger printers, this unit is a solid performer. Your busy office or workgroup gets fast, affordable and versatile devices that can expand from desktop models to mighty four-tray, floor-standing powerhouses.
Black and white
This mono device has a resolution of 1200 x 600 dpi which produces quality black and white prints. -
45 pages per minute (ppm)
Fast printing of up to 45 ppm on the SP 5200s for single sided printing - quickly handling even the most demanding jobs. -
Easy on the environment
This device is ENERGY STAR compliant and includes double-sided (duplex) printing as standard. -
Reduce your costs
With its low Total Cost of Ownership (TCO) and high toner yield, this device is competitively priced printers that small to medium workgroups will quickly find indispensable. -
Maximize your workspace and minimize the effort
Space-efficient, the compact A4 multifunction printers don't intrude on valuable workspace in the office. Set-up and operation are simple and straightforward. It also gives you a large dimension touch panel and also features a tilting function that can be adjusted for ease of use. -
Keep confidential documents confidential
You have the choice of a full suite of security tools to keep your data safe. For example, hard copies that won't print until a PIN is entered and you can restrict the use of the multifunctional printers to approved groups or individuals.
- Ricoh SP 5200S - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Max Copying Speed
- Up to 45 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 45 ppm
- Max Printing Resolution
- Up to 1200 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
- Scanning
- 600 dpi
- Original Size
- A5 (148 x 210 mm) (min) - A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, thin paper
- Standard Media Capacity
- 650 sheets
- Max Media Capacity
- 2300 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- Office Machine Features
- Scan to e-mail, scan to folder
- Power
- AC 230 V (50/60Hz)
- 46 cm x 51 cm x 68.6 cm
- 45 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - monochrome
- Interface
- Standard Memory
- 1 GB
Copying
- Max Copying Speed
- Up to 45 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Preset Enlargements
- 141%, 200%
- Preset Reductions
- 50%, 71%, 93%
- Maximum Copies
- 999
Printing
- Up to 45 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF
- First Print Out Time B/W
- 7.5 sec
Scanning
- Optical Resolution
- 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- Total Memory Capacity
- Up to 320 pages
Document & Media Handling
- Min Original Size
- A5 (148 x 210 mm)
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 52 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), C5 (162 x 229 mm), C6 (114 x 162 mm), B6 (125 x 176 mm), 216 x 900 mm, Oficio (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), Monarch (98.4 x 190.5 mm)
- 650 sheets
- 2300 sheets
- 100 sheets
- 500 sheets
- Input tray - 550 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 220 g/m² , Bypass tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 220 g/m² , RADF - 50 sheets - 216 x 1260 mm
- Speed Details
- Printing: up to 45 ppm (A4) - B/W , Scanning: up to 30 ipm (Letter A) - B/W
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- SSL, TLS, IPsec
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2 x64 Edition
- Software Included
- Web Image Monitor, DeskTopBinder Lite, Remote Communication Gate S Pro, App2me, SmartDeviceMonitor
- Voltage Required
- 1500 Watt
- Power Consumption Standby
- 8 Watt
- Warm-Up Time
- 20 sec
- First Copy Out Time B/W
- 7.5 sec
- Consumables Included
- 1 x toner cartridge (black)
- Supported Windows 7 Features
- Windows HD Imaging
- ISO 9001, ISO 140001, ISO/IEC 19752
- ENERGY STAR Certified
- 46 cm
- 51 cm
- 68.6 cm
- 45 kg
