Just because your budget is tight or your office is limited on space, it shouldn't limit what you can do. Use the Ricoh SP 4510SF to perform a wider range of everyday document management tasks - including printing, scanning, faxing and copying quickly - so you can move from one project to the next without missing a beat. Place the compact MFP nearly anywhere, even on your desk, to save space while you save time.
Customize the device to accommodate personal preferences. Take advantage of security controls to protect your information. Access administrative controls remotely to keep the SP 4510SF running efficiently - whether you add it to an integrated Ricoh Managed Document Services (MDS) portfolio or use it as your primary device.
Tackle big tasks in small spaces
You need a powerful multifunction printer to take on more challenges - not take up space. With the Ricoh SP 4510SF, you can perform a wider range of everyday information management tasks in any office, or from any desk. Need to print quickly? Use the device to print at 42 ppm and transition quickly to the next job. Need to impress a client? Print documents with crisp, clear text and graphics in high-quality 1200 dpi resolution without compromising speed. -
Customize your commands
Nobody knows how to improve your productivity more than you do. That's why Ricoh designed the Ricoh SP 4510SF with customizable controls that complement your workflow demands. Set shortcuts for frequently used tasks right on the tilting 4.3" color touch panel Home Screen. Need to work on the go? Bring your work with you on a USB memory card or SD card and print it when you need it. Or, simply use your smartphone or tablet for convenient mobile printing. The Ricoh Smart Device Print&Scan app gives you more functionality and control for programming jobs, it's the closest you can get to the PC experience on a tablet or smartphone. -
Simplify complex tasks
Want to accomplish more by working less? With the Ricoh SP 4510SF, you can automate a wide range of processes to save time so you can move on to your next project. Remotely check supply levels, system settings, usage rates and more to ensure the device is ready to work when you are. -
Share information quickly
You have important information. But can you get it to the right people at the right time, so they can make game-changing decisions for your organization? Send any document in color within moments with Scan-to-Email/Folder/URL/USB/SD Card. Create searchable PDFs when scanning with Ricoh's OCR option. The SP 4510SF supports Distributed Scan Management (DSM) which allows administrators to create predefined recipient-specific, scanning workflows centrally to simplify scanning to different users. You can even scan two-sided documents, including IDs and patient insurance cards, onto a single sheet of paper to reduce paper costs. For those times when you need to fax legal or other professional documents, you can take advantage of advanced fax capabilities, including forwarding to Email and Folder, Internet Fax, support for LDAP and more. -
Conserve energy, protect your budget
Use less energy to do more work. With recovery from sleep mode under 10 seconds, and first-copy times at 5.1 seconds, you won't have to spend a lot of your time waiting for the information you need. Program automatic startup or shutdown to conserve energy when you're out of the office. Reduce paper costs with default double-sided printing. You can even check to see if your efforts are worthwhile. The MFP includes an indicator that prominently displays paper-saving metrics to encourage more sustainable printing. Plus, the device meets EPEAT Silver criteria - a global environmental rating system for electronic products - and is certified with the latest ENERGY STAR specifications. -
Control critical information
Keep prying eyes off of your confidential information. When you deploy advanced user authentication controls, a proximity card swipe or login and password entry at the device is required to access critical functions, including the release of documents. You can also restrict access to specific functions for specific users to curb unnecessary printing. Other security features include Data Overwrite Security System (DOSS) and embedded encryption to help protect images and data on the Ricoh SP 4510SF hard drive.
- Ricoh SP 4510SF - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- LED (monochrome)
- Monthly Duty Cycle (max)
- 150000 pages
- Max Copying Speed
- Up to 40 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 40 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 200 x 200 dpi
- Scanning
- 600 dpi
- Display
- 4.3"
- Original Size
- 100 x 148 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, recycled paper, thick paper, preprinted paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 1600 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- Office Machine Features
- Save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to Cloud, scan to FTP, scan to SMB
- Power
- AC 230 V (50/60Hz)
- 41.9 cm x 42.7 cm x 48.4 cm
- 23 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- LED - monochrome
- 150000 pages
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 1 GB
- Max Supported Memory
- 1.5 GB
- Supported Flash Memory
- SD Memory Card
Copying
- Max Copying Speed
- Up to 40 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, Sort, auto start, rotation copy, margin shift, Auto Tray Switching (ATS), mixed size copy
Printing
- Up to 40 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3
- First Print Out Time B/W
- 6 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- 200 x 200 dpi
- Max Battery Backup Time
- 12 hour(s)
Fax Machine Features
- Fax forwarding, LAN fax, Dual Access, fax memory backup, Duplex Fax
Document & Media Handling
- Min Original Size
- 100 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 52 g/m²
- Max Media Weight
- 162 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm), Foolscap (216 x 343 mm)
- 600 sheets
- 1600 sheets
- 50 sheets
- 250 sheets
- Input tray - 600 sheets size: 100 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m² , Bypass tray - 50 sheets size: 60 x 127 mm - 216 x 900 mm weight: 52 g/m² - 162 g/m² , ADF - 50 sheets weight: 52 g/m² - 162 g/m²
- Speed Details
- Printing: up to 40 ppm (A4) - B/W , Copying: up to 40 ipm - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Kerberos, LDAP, IPsec, 802.1x
- Operating System Support
- MS Windows XP, Red Hat Linux, IBM AIX, HP-UX, MS Windows Server 2003, MS Windows 7, Sunsoft Solaris, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5 or later, Novell NetWare 6.5 or later, MS Windows Server 2012, Windows 8, SCO OpenServer, Windows 8.1, MS Windows Server 2012 R2
- Software Included
- Web Image Monitor, SmartDeviceMonitor, Web SmartDeviceMonitor
- Voltage Required
- 1.1 kW
- Power Consumption Standby
- 97.2 Watt
- Power Consumption Sleep
- 0.72 Watt
- Warm-Up Time
- 19 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages
- ISO/IEC 19752
- ENERGY STAR Certified
- 41.9 cm
- 42.7 cm
- 48.4 cm
- 23 kg
