This compact unit with a small footprint makes the SP 3600SF well suited to the needs of small offices that need to copy and scan as well as print. Standard connectivity is via USB or networked via Gigabit Ethernet. There is also the option of WiFi connection so the SP 3600SF can be conveniently located anywhere in the office where there is a power outlet. It takes up little space and uses minimal energy when not in use. But when needed the SP 3600SF is available for use in just 13 seconds, producing a first print in just 6.5 seconds and can handle large volumes of work in bust office environments.
- Ricoh SP 3600SF - multifunction printer - B/W
- Multifunction printer
- Fax Type
- G3 - plain paper
- Printing Technology
- LED (monochrome)
- Monthly Duty Cycle (max)
- 50000 pages
- Max Copying Speed
- Up to 30 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 30 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Media Size
- Media Type
- Plain paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 850 sheets
- Output Trays Capacity
- 125 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to FTP, scan to SMB
- Power
- AC 230 V (50/60Hz)
- 40 cm x 39.2 cm x 40.6 cm
- 19 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- LED - monochrome
- 50000 pages
- Interface
- Standard Memory
- 512 MB
Copying
- Max Copying Speed
- Up to 30 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 30 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3
- First Print Out Time B/W
- 6.5 sec
Scanning
- Optical Resolution
- 600 dpi
Fax Machine
- Compatibility
- G3
- Max Transmission Speed
- 33.6 Kbps
Fax Machine Features
- Fax memory backup
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- Max Media Size
- A4
- Min Media Weight
- 52 g/m²
- Max Media Weight
- 162 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- 350 sheets
- 850 sheets
- 125 sheets
- Input tray - 350 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m² , Output tray - 125 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m²
- Speed Details
- Printing: up to 30 ppm (A4) - B/W , Copying: up to 30 ipm - B/W
- 1 x USB 2.0 , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Windows 8.1, Apple Mac OS X 10.6 or later, MS Windows Server 2012 R2
- Voltage Required
- 1.006 kW
- Power Consumption Sleep
- 1 Watt
- Warm-Up Time
- 19 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1500 pages
- ENERGY STAR Certified
- 40 cm
- 39.2 cm
- 40.6 cm
- 19 kg
