Small, smart and energy-efficient, the SP 311SFN is designed to impress. Compact enough to fit unobtrusively on a desk, the innovative B/W A4 laser MFP will astound you with their speed and efficiency. The device is easy to operate and simple to maintain. Their energy consumption is very low. And it incorporates a host of environmentally responsible features such as energy saver mode and automatic duplex to lower your carbon footprint. In short, if you're looking for fast, compact, energy-efficient B/W MFP, you'll find them in the SP 311SFN.
- Ricoh SP 311SFN - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Max Copying Speed
- Up to 28 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 28 ppm
- Max Printing Resolution
- Up to 1200 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Media Size
- Media Type
- Plain paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 300 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 50 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN
- Office Machine Features
- Scan to e-mail, scan to folder
- Power
- AC 230 V (50/60Hz)
- 40.5 cm x 38.2 cm x 39 cm
- 17.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - monochrome
- Display
- 4 lines
- Interface
- USB 2.0, LAN
- Standard Memory
- 128 MB
- Max Supported Memory
- 128 MB
Copying
- Max Copying Speed
- Up to 28 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 28 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6
Scanning
- Optical Resolution
- 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Max Media Size
- A4
- Min Media Weight
- 52 g/m²
- Max Media Weight
- 162 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- 300 sheets
- 300 sheets
- 50 sheets
- 50 sheets
- Input tray - 250 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m² , Bypass tray - 50 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m² , Output tray - 50 sheets - A4 (210 x 297 mm)
- Speed Details
- Printing: up to 28 ppm (A4) - B/W , Copying: up to 28 ppm (A4) - B/W , Scanning: up to 12 ppm (A4) - B/W , Scanning: up to 6 ppm (A4) - colour
- 1 x USB 2.0 , 1 x LAN - RJ-45
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2012
- Voltage Required
- 890 Watt
- Warm-Up Time
- 30 sec
- First Copy Out Time B/W
- 8 sec
- ISO 9001, ISO 14001
- ENERGY STAR Certified
- 40.5 cm
- 38.2 cm
- 39 cm
- 17.5 kg
