Printing has never been easier. The Ricoh SP 311DNw lets you place high quality black and white laser printing wherever you need it. Simple to use and easy to maintain, this 30-page-per-minute laser printer delivers all the basic features any small office or workgroup needs - plus the convenience of wireless networking for flexible placement.
Cut the cord
The ultra-compact Ricoh SP 311DNw fits comfortably on or under a desk for easy installation to a connected PC. But why limit your options to hardwired connections? In addition to standard USB 2.0 and 10/100Base-TX Ethernet connectivity, the SP 311DNw offers embedded IEEE 802.11 b/g/n Wireless LAN network communications with authentication and encryption. Now you can place the printer where it is most convenient for everyone in the office to share. No cables, no complex setup, no physical limitations on where to install trouble-free, secure Wi-Fi enabled laser printing. -
Simple Windows printing
At 30-ppm the Ricoh SP 311DNw is designed to make fast work of everyday printing jobs in common Windows environments. However you choose to connect to the SP 311DNw, its powerful 360 MHz controller with 128 MB memory quickly processes files at up to 1200 x 600 dpi resolution for sharp text and graphics on every page. The intuitive PCL 6 driver makes it easy to program duplex print jobs, combine multiple pages onto a single sheet, imprint watermarks on pages, and add front covers to sets to produce professional looking documents with just a few clicks. -
Business-class media
The Ricoh SP 311DNw is built for demanding offices. The versatile 250-sheet front-loading paper tray and 50-sheet Bypass both accept media from postcard to legal size and up to 90 lb. Index in weight. Print quantities of envelopes and stacks of collated sets with minimal reloading. Standard automatic duplexing saves paper while a 125-sheet top exit tray makes it easy to grab your pages and get back to business. -
Easy to use and affordable to own
The Ricoh SP 311DNw is so simple to use and dependable, with only a few hard keys and LED indicators to operate the printer. Installation and device monitoring are performed through Ricoh's web image monitor and smart organizing monitor utilities. Plus, it uses Ricoh's proven all-in-one print cartridge technology for simplified maintenance and minimal per-page costs. Reliable and durable, the AIO cartridge is the only supply you'll ever need - it contains everything that can run out - and can be changed by anyone in a clean, effortless process in seconds.
- Ricoh SP 311DNw - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 12.7 kg
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Print Speed
- Up to 28 ppm - B/W
- Max Resolution (B&W)
- 1200 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- RAM Installed (Max)
- 128 MB (128 MB)
- Language Simulation
- PCL 5E, PCL 6
- Media Type
- Plain paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet bypass tray
- Monthly Duty Cycle (max)
- 20000 pages
- Networking
- Print server
- System Requirements
- Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008, Microsoft Windows Server 2012
- 37 cm x 38.2 cm x 26.2 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 1200 x 600 dpi
- First Print Out Time B/W
- 8 sec
- PCL 5E, PCL 6
- Media Handling
RAM
- 128 MB / 128 MB (max)
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Weight
- 52 g/m² - 162 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 250 sheets weight: 52 g/m² - 162 g/m² , 1 x automatic - 50 sheets weight: 52 g/m² - 162 g/m²
- Max Media Capacity
- 300 sheets
- Output Trays Capacity
- 125 sheets
Duty Cycle
- 20000 pages
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- ISO 140001, ISO 14001, ISO 27001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 890 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- 37 cm
- 38.2 cm
- 26.2 cm
- 12.7 kg
