Ricoh SP 311DN Mono Laser Printer
Quicklinx: 8ZRWWS00 Mfr#: 995499
Small, smart and energy-efficient, the SP 311DN is designed to impress. Compact enough to fit unobtrusively on a desk, the B/W A4 laser printer will astound you with their speed and efficiency. The device is easy to operate and simple to maintain. Its energy consumption is very low. And it incorporates a host of environmentally responsible features such as energy saver mode and automatic duplex to lower your carbon footprint. In short, if you're looking for fast, compact, energy-efficient B/W printer, you'll find them in the SP 311DN.
  • Budget-friendly and highly productive
    The long-lasting, high-yield, all-in-one toner cartridge gives you an attractive cost per print. Along with a low hardware price, the SP 311DN is therefore affordable investments for cost-conscious offices. This device is also extremely productive. It only takes 26 seconds to warm up and speed along at a fast 28 pages per minute. Automatic duplex further improves productivity - and saves paper too.
  • Simple to connect
    With standard USB 2.0 and a built-in Network Interface Card (all models), plus Wi-Fi possibilities, these devices will fit neatly into your existing network. You can send each job to the most appropriate network machine. That way, you get the best value from each of your output systems. Fax quickly and efficiently with PC Fax and Super G3 Fax capabilities.
  • Environmentally responsible
    Lower your environmental impact with features such as short warm-up time, sleep mode, automatic duplex printing, Energy Saver mode, and low typical electricity consumption. In addition, these devices are ENERGY STAR compliant. This means less CO2 is produced in providing the energy needed to run them.
  • Easy to use
    Full-front operation is straightforward as all the devices feature just a few buttons. You can also send scans to email, folder or FTP and copy both sides of an ID card onto one side of paper. For all models the standard tray takes up to 250 sheets while the 50-sheet bypass tray can be used as second paper tray.
Ricoh SP 311DN - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
12.7 kg
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Print Speed
Up to 28 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 600 dpi
Automatic Duplexing
USB 2.0, LAN
RAM Installed (Max)
128 MB (128 MB)
Language Simulation
PCL 5E, PCL 6
Media Type
Plain paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet bypass tray
Monthly Duty Cycle (max)
20000 pages
Print server
Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008, Microsoft Windows Server 2012
37 cm x 38.2 cm x 26.2 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wired
USB 2.0, LAN
1200 x 600 dpi
Automatic Duplexing
First Print Out Time B/W
8 sec
Language Simulation
PCL 5E, PCL 6
Media Handling
RAM
RAM Installed (Max)
128 MB / 128 MB (max)
Media Handling
Media Type
Plain paper
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Weight
52 g/m² - 162 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets weight: 52 g/m² - 162 g/m² , 1 x automatic - 50 sheets weight: 52 g/m² - 162 g/m²
Max Media Capacity
300 sheets
Output Trays Capacity
125 sheets
Duty Cycle
20000 pages
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
ISO 140001, ISO 14001, ISO 27001
Power supply - internal
Frequency Required
50/60 Hz
890 Watt
Power Consumption Stand by
50 Watt
Environmental Standards
ENERGY STAR
37 cm
38.2 cm
26.2 cm
12.7 kg
