Product
Ricoh SP 211SF 22PPM A4 Mono Laser 4-in-1 MFP
Quicklinx: B7Y3WS00 Mfr#: 904235
The SP 211SF offers everything a small/home office is looking for. Productivity is enhanced with a 22 ppm print speed, color scanning, G3 faxing, manual double-sided printing and high speed USB 2.0. This versatile MFP is easy to use via the user-friendly 4-line LCD panel. All operations can be conveniently managed from the front of the device. The reliable SP 211SF is rounded off by a small footprint, low energy consumption and a cost-efficient all-in-one print cartridge.
Ricoh SP 211SF - multifunction printer - B/W
Multifunction printer
Fax Type
G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
20000 pages
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 22 ppm
Max Printing Resolution
Up to 1200 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Media Size
Media Type
Plain paper
Standard Media Capacity
150 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
50 sheets
Connection Availability
USB 2.0
AC 230 V (50/60Hz)
40.2 cm x 36 cm x 29.3 cm
11.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
20000 pages
USB 2.0
Standard Memory
8 MB
Copying
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Up to 22 ppm
Printer Drivers / Emulations
Windows GDI driver
Scanning
Optical Resolution
600 dpi
Fax Machine
Compatibility
G3
Max Transmission Speed
33.6 Kbps
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
105 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
150 sheets
1 sheet
50 sheets
Input tray - 150 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet weight: 60 g/m² - 105 g/m² , Output tray - 50 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , ADF weight: 52 g/m² - 105 g/m²
Speed Details
Printing: up to 22 ppm
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2003 R2, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2
AC 230 V (50/60Hz)
400 Watt
Power Consumption Standby
65 Watt
Power Consumption Sleep
5 Watt
Warm-Up Time
25 sec
First Copy Out Time B/W
10 sec
Consumables Included
1 x Cartridge (black) - up to 1000 pages
ISO 9001, ISO 14001, ISO 27001
ENERGY STAR Certified
40.2 cm
36 cm
29.3 cm
11.1 kg
