Imagine the power of versatile color on demand. Rethink your approach to color multitasking with Ricoh's innovative GELJET multifunctionals. Equally at home in both retail and office environments, the Aficio SG 3100SNw provide fast color copying, printing, scanning and faxing for everyone. And they make it easy with simple front access, a small footprint and the cable-free connectivity of Wi-Fi.
Space-saving design
These compact MFPs save you space in retail and office environments. Everything is easily accessible from the front, so you can slide GELJETS into the smallest of spaces. -
Versatile networking
GELJET MFPs offer extended network capability. Wi-Fi connection is standard, enabling easy printing from locations normally inaccessible using cables. -
Unique ECOnomy color
In ECOnomy color mode, GELJETs can distinguish between text and images - text is printed solid black, while image thickness is reduced by half. -
Nice and simple operation
Simplify everyday tasks with the SG 3100SNw's easy-touse control panel. Benefit from a 'one touch' solution key that allows you to personalize your routine jobs. Access every essential operation from the front, including paper and ink cartridges without moving your MFP. -
Bring high quality in-house
Produce professional looking results in-house. Print on a wide range of paper sizes and weights up to 256 g/m2 thick via the optional bypass tray. Quick drying Liquid Gel allows clear sharp prints up to true 3600 x 1200 dpi, and enables high speed duplex printing.
- Ricoh SG 3100SNw - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Ricoh GelJet - 4-ink
- Max Copying Speed
- Up to 29 ppm (mono) / up to 29 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 3600 x 1200 dpi (mono) / up to 3600 x 1200 dpi (colour)
- Scanning
- 1200 x 1200 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Media Size
- Media Type
- Plain paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 850 sheets
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi
- Power
- AC 230 V (50/60Hz)
- 39.9 cm x 43.65 cm x 32.95 cm
- 15.3 kg
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified, Blue Angel
- Copier Type
- Digital
- Ink-jet - colour
- Interface
- Max Supported Memory
- 256 MB 256 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Preset Enlargements
- 141%, 200%, 100%
- Preset Reductions
- 50%, 71%, 93%
- Maximum Copies
- 99
Printing
- Inkjet Technology
- Ricoh GelJet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 6, PCL 5c, Ricoh RPCS
- First Print Out Time B/W
- 5.5 sec
- First Print Out Time Colour
- 6.5 sec
Scanning
- Optical Resolution
- 1200 x 1200 dpi
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Max Media Size
- A4
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- 250 sheets
- 850 sheets
- 100 sheets
- Speed Details
- Copying: up to 29 ppm - B/W , Copying: up to 29 ppm - colour , Printing: up to 29 ppm - B/W , Printing: up to 29 ppm - colour
- 1 x USB 2.0 , 1 x LAN
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.5 or later
- Software Included
- Drivers & Utilities
- Voltage Required
- 45 Watt
- Power Consumption Standby
- 3.1 Watt
- Warm-Up Time
- 35 sec
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Blue Angel Compliant
- 39.9 cm
- 43.65 cm
- 32.95 cm
- 15.3 kg
