This digital camera is equipped with a high-performance lens with a maximum aperture 2.0. It has superior brightness with the folded optic zoom lens and is equipped with a high-performance 4.0x optical zoom lens of maximum aperture 2.0. Since the lens is bright, the sensitivity is suppressed even when shooting with the same shutter speed and allows recording in high image quality in dark scenes.
High-performance lens
The camera has superior brightness with the folded optic zoom lens and is equipped with a high-performance 4.0x optical zoom lens of maximum aperture 2.0. Since the lens is bright, the sensitivity is suppressed even when shooting with the same shutter speed and allows recording in high image quality in dark scenes. -
High sensitivity backside illumination CMOS image sensor
It's equipped with a backside illuminated CMOS image sensor with excellent light receiving efficiency and offers images with low noise and superior resolution with high definition. -
Equipped with an electromagnetic compass
You can display the electromagnetic compass on the LCD monitor and check the latitude, longitude, and atmospheric pressure of the current location. It's also equipped with a GPS function that records the location information on the shooting data.
- Ricoh WG-5 GPS - digital camera
- Product Type
- Digital camera - 1080p - compact
- Memory Card Slot
- SD card
- Sensors
- Digital compass, barometer, pressure sensor, digital level metre
- Sensor Resolution
- 16.0 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 4x zoom - 4.5 - 18 mm - f/2.0-4.9
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 40 cm
- Digital Zoom
- 7.2x
- Image Stabiliser
- Optical (image sensor shift mechanism)
- Camera Flash
- Built-in flash
- Display
- LCD display - 3"
- Supported Battery
- Pentax D-Li92 Li-ion rechargeable battery (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Silver
- 12.5 cm x 3.2 cm x 6.45 cm
- 216 g
- Product Type
- Built-in Light
- LED lights
- Enclosure Colour
- Silver
- Sensor Resolution
- 16.0 Megapixel
- Optical Sensor Type
- BSI-CMOS
- Total Pixels
- 16,790,000 pixels
- Effective Sensor Resolution
- 16,000,000 pixels
- Optical Sensor Size
- 1/2.3"
- ISO (Max)
- 6400
- Optical Zoom
- 4x
- Digital Zoom
- 7.2x
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- HDR Mode
- Auto HDR mode
- Navigation
- GPS receiver
- Sensors
- Print Standard
- DPOF support, Exif Print support, PRINT Image Matching
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 9
- AE/AF Control
- Subject-tracking AF
- Face Detection
- Blink Detection technology, Face Detection AF/AE, Pet Detection, Smile Capture, Self Portrait Auto Shutter
- Digital Video Format
- H.264, AVC
- Image Recording Format
- JPEG
- 1920 x 1080
- Interface
Exposure & White Balance
- Light Sensitivity
- ISO auto, ISO 125-6400
- Exposure Metering
- Multi-segment, centre-weighted, spot
- Exposure Modes
- Programme, automatic, shutter-priority
- Shooting Programs
- Landscape, portrait mode, macro, text, surf & snow, PET, Blue Sky, food, fireworks, flower, night scene, Underwater, sports mode, sunset, candle, night scene with portrait, kids, report, digital microscope, underwater movie, handheld night shot, interval composite mode, Dynamic Range (HDR), digital IS, green, portrait & sunset, portrait & backlight, portrait & blue sky, group photo
- Special Effects
- Soft, Black & White, Sepia, Colour, fisheye, miniature, Retro, Colour Extract, brightness, Toy camera, starburst, High contrast, Color Emphasis, Collage
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Tungsten light, daylight, shade, fluorescent light (daylight), fluorescent light (daylight white), fluorescent light (white)
- Max Shutter Speed
- 1/4000 sec
- Min Shutter Speed
- 4 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
Lens System
- Focal Length Equivalent to 35mm Camera
- 25 - 100mm
- Focus Adjustment
- Automatic, manual
- 40 cm
- Macro Focus Range
- 1-50cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 7 groups / 9 elements
- Aspherical lens
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator
- Effective Flash Range
- 0.2 m - 10.4 m: ISO auto (wide lens) , 0.2 m - 4.2 m: ISO auto (tele lens)
Additional Features
- Self-Timer Delay
- 10 sec, 2sec, 3sec
- Additional Features
- RGB primary colour filter, date/time stamp, digital image rotation, in-camera red-eye removal, cropping an image, resizing an image, interval shooting mode, in-camera film editing, Dynamic Range Adjustment, Pixel Track SR, HDR image enhancement technology, NR Slow Shutter, high-speed recording, Time-Lapse recording, Interval Movie Record
Display
- 3" LCD display
- Display Format
- 460,000 pixels
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- USB 2.0 , Composite video/audio output , HDMI output (19 pin micro HDMI Type D)
Software
- Software
- Drivers & Utilities, ArcSoft MediaImpression 2.2 LE, ArcSoft MediaImpression 3.6.2 LE
- Included Accessories
- AC power adaptor, USB cable, macro stand, carabiner strap
- Protection
- Waterproof, crushproof, freezeproof, shockproof, dust-resistant
- Underwater Use
- Underwater Depth
- Up to 14 m
- Battery Type
- Pentax D-Li92 Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 240 shots , Playback - 3.3 hours , Video recording - 1.1 hours
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Memory Card Included
- No
- Image Storage
- JPEG 4608 x 3456 , JPEG 3456 x 3456 , JPEG 4608 x 2592 , JPEG 3072 x 2304 , JPEG 3072 x 1728 , JPEG 2592 x 1944 , JPEG 2592 x 1464 , JPEG 2048 x 1536 , JPEG 1920 x 1080 , JPEG 1024 x 768 , JPEG 640 x 480
- Video Capture
- H.264 - 1920 x 1080 - 30 fps , H.264 - 1280 x 720 - 60 fps , H.264 - 1280 x 720 - 30 fps
- 12.5 cm
- 3.2 cm
- 6.45 cm
- 216 g
- -10 °C
