Product
Brand
Ricoh Afico SP 5210DN MonoNetwork Laser Printer
Quicklinx: 86RTWS00 Mfr#: 974924
User-friendly, eco-friendly and cost-efficient, the SP 5210DN printer supports the print needs of busy offices on a budget. You enjoy impressive print speeds, automatic duplexing, excellent paper handling and the security features. For larger workgroups, the space-saving designs can expand from desktop models to five-tray floor-standing powerhouses.
Ricoh SP 5210DN - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
23 kg
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Print Speed
Up to 50 ppm - B/W
Max Resolution (B&W)
1200 x 600 dpi
Automatic Duplexing
USB, LAN, USB host
533 MHz
RAM Installed (Max)
768 MB (768 MB)
Hard Drive
80 GB
Language Simulation
PCL 5E, PostScript 3, PCL 6, PDF, XPS
Media Type
Envelopes, transparencies, labels, plain paper, recycled paper, thick paper, thin paper
Total Media Capacity
650 sheets
Media Handling
550-sheet input tray, 100-sheet bypass tray
Monthly Duty Cycle (max)
200000 pages
Recommended Monthly Volume
5000 - 15000 pages
Print server - Ethernet, Fast Ethernet - integrated
AC 230V
UNIX, Citrix Presentation Server, Apple MacOS X 10.2 or later, Microsoft Windows Server 2003, Apple MacOS X 10.2 - 10.2.6, Novell NetWare 6.5 or later, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Silver
41.1 cm x 43.5 cm x 40 cm
Printer Type
Printer
Print Speed
Up to 50 ppm - B/W
Built-in Devices
Status LCD
Wired
USB, LAN, USB host
1200 x 600 dpi
Automatic Duplexing
First Print Out Time B/W
7.5 sec
Language Simulation
Fonts Included
58 x PCL , 136 x PostScript 3
Media Handling
533 MHz
RAM
RAM Installed (Max)
768 MB / 768 MB (max)
Storage
Hard Drive
80 GB
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Media Sizes
A4 (210 x 297 mm), A6 (105 x 148 mm)
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm)
Media Weight
52 g/m² - 220 g/m²
650 sheets
Media Feeders
1 x automatic - 550 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 220 g/m² , 1 x automatic - 100 sheets weight: 52 g/m² - 220 g/m²
Max Media Capacity
2850 sheets
Output Trays Capacity
500 sheets
Duty Cycle
200000 pages
5000 - 15000 pages
Print server - integrated
Network / Transport Protocol
TCP/IP, IPX/SPX, AppleTalk, Bonjour
Remote Management Protocol
SNMP 3
Security Protocols & Features
SSL, IPsec
Expansion Slots
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 6000 pages
Supported Windows 7 Features
Windows HD Imaging
cUL, UL 60950-1, CAN/CSA C22.2 No. 60950-1
Power supply - internal
AC 230V
Frequency Required
50 - 60 Hz
1.4 kW
Power Consumption Stand by / Sleep
5 Watt
Software Included
Font Manager 2000, Web Image Monitor
EPEAT Compliant
EPEAT Silver
ENERGY STAR
41.1 cm
43.5 cm
40 cm
23 kg
