The Aficio SP 3510SF black and white A4 MFP gives you smart new ways to print, copy, scan and fax. It significantly reduces your costs and improves the speed and agility of your business. This device is packed with all the features you would expect from a top-of-the-range MFP in terms of speed, image quality and paper handling options. Plus, it is compact and easy-to-maintain.
