The SP 211 is an affordable monochrome laser printer with a 150 sheet standard paper capacity from an embedded tray. High speed USB 2.0 connectivity makes the SP 211 suitable as a personal printer.
- Ricoh SP 211 - printer - B/W - laser
- Printer Type
- Personal printer - laser - B/W
- 7.2 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 100 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 22 ppm - max speed
- Max Resolution (B&W)
- 1200 x 600 dpi
- Interface
- USB 2.0
- RAM Installed (Max)
- 128 MB
- Language Simulation
- Windows GDI driver
- Media Type
- Plain paper, recycled paper
- Total Media Capacity
- 150 sheets
- Media Handling
- 150-sheet input tray, 1-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 20000 pages
- Recommended Monthly Volume
- 400 pages
- System Requirements
- Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1
- Microsoft Certification
- Compatible with Windows 7
- 40.2 cm x 36 cm x 16.5 cm
- Printer Type
- Personal printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB 2.0
- 1200 x 600 dpi
- First Print Out Time B/W
- 10 sec
- Media Handling
RAM
- 128 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 100 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 148 mm, B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 105 g/m²
- 150 sheets
- Media Feeders
- 1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m²
- Output Trays Capacity
- 50 sheets
Duty Cycle
- 20000 pages
- 400 pages
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge - up to 700 pages ISO/IEC 19752
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 400 Watt
- Power Consumption Stand by
- 65 Watt
- Power Consumption Sleep
- 5 Watt
- OS Required
- Sound Emission (Idle)
- 16.5 dBA
- Sound Emission (Operating)
- 56.7 dBA
- 40.2 cm
- 36 cm
- 16.5 cm
- 7.2 kg
