Ricoh A4 Mono Laser Printer 40ppm Mono
Quicklinx: B745WS00 Mfr#: 906227
As new projects and challenges emerge, you differentiate yourself by stepping up, staying on task and meeting the tightest deadlines. But sometimes, even the hardest-working employee needs a little help. Ricoh understands.
After all, Ricoh has built a legacy of helping hard-working people move information and ideas effortlessly - with innovations like the Ricoh SP 4510DN. Print a wide range of high-quality black-and-white documents at high speeds and move on to the next project quickly. You'll be saving more than time. You can fit the compact, feature-rich printer into virtually any workflow, workgroup - and budget.
  • Meet challenging print demands
    Ready to get started? Recovery from sleep mode is only 10 seconds, so you can print up to 42 pages per minute at 1200 dpi resolution and complete large jobs quickly. The SP 4510DN is equipped with a powerful 533 MHz controller and 512 MB RAM standard to support busy offices.
  • Manage more print jobs with ease
    Spend more time on your next big idea, and less time figuring out how to print it. Navigate key functions and check system status at a glance using the four-line LCD panel on the Ricoh SP 4510DN.
  • Print conveniently in more places
    Smartphones and tablets continue to expand their presence in the workplace. Why? Because they help you perform more tasks while on the move. Now you can print from them, too. Print images, documents, photographs and more directly from your Apple iPhone, iPad or Android mobile device using the Ricoh Smart Device Print&Scan app when connected to an office network - without installing print drivers. It's similar to printing from your desktop computer, with the added convenience of mobility to share information in more ways.
  • Secure documents and people
    The Ricoh SP 4510DN helps protect critical information with advanced controller capabilities. Plus, you'll have built-in controller features including 128-bit data encryption, IP Address Filtering and more to help prevent information theft, interception and falsification.
  • Be responsible inside and outside the office
    You take pride in your work. Take pride in how you do it, too. The Ricoh SP 4510DN comes standard with automatic double-sided printing so you can reduce paper usage and costs. Worried about the printer being left on overnight? Set it to power on/off at designated times and save energy. Or, rely on the ECO-Night Sensor to shut the printer down automatically when the lights are turned off. Plus, the device meets EPEAT Silver criteria - a global environmental rating system for electronic products - and is certified with the latest ENERGY STAR specifications.
  • Monitor your performance
    It's easy to say you're saving money and increasing efficiency. It's another thing to prove it. Use Ricoh's Web Image Monitor to check system status, change settings, manage job queues and expedite maintenance right from the desktop. You can even assign up to 1000 user codes to track volumes and trends by individual users, and leverage the information to improve print behavior.
Ricoh SP 4510DN - printer - monochrome - LED
Printer Type
Workgroup printer - LED - monochrome
14 kg
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
RAM Installed (Max)
512 MB (1.5 GB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, PDF
Media Type
Plain paper, recycled paper, thick paper, thin paper, preprinted paper
Total Media Capacity
250 sheets
Monthly Duty Cycle (max)
150000 pages
Print server
Printer Features
Print from mobile device
AC 230V
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5 or later, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Microsoft Certification
Compatible with Windows 7
37 cm x 39.2 cm x 30.6 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
5 sec
Language Simulation
Fonts Included
45 x PCL , 136 x PostScript 3 , 13 x Intellifonts
Printer Features
RAM
RAM Installed (Max)
512 MB / 1.5 GB (max)
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Weight
52 g/m² - 162 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m²
Max Media Capacity
1600 sheets
Output Trays Capacity
250 sheets
Duty Cycle
150000 pages
Print server
Security Protocols & Features
LDAP, 802.1x
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19752
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
1110 Watt
Environmental Standards
ENERGY STAR
37 cm
39.2 cm
30.6 cm
14 kg
