As new projects and challenges emerge, you differentiate yourself by stepping up, staying on task and meeting the tightest deadlines. But sometimes, even the hardest-working employee needs a little help. Ricoh understands.
After all, Ricoh has built a legacy of helping hard-working people move information and ideas effortlessly - with innovations like the Ricoh SP 4510DN. Print a wide range of high-quality black-and-white documents at high speeds and move on to the next project quickly. You'll be saving more than time. You can fit the compact, feature-rich printer into virtually any workflow, workgroup - and budget.
- Ricoh SP 4510DN - printer - monochrome - LED
- Printer Type
- Workgroup printer - LED - monochrome
- 14 kg
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Print Speed
- Up to 40 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- RAM Installed (Max)
- 512 MB (1536 MB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PDF
- Media Type
- Plain paper, recycled paper, thick paper, thin paper, preprinted paper
- Total Media Capacity
- 250 sheets
- Monthly Duty Cycle (max)
- 150000 pages
- Networking
- Print server
- Printer Features
- Print from mobile device
- Power
- AC 230V
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5 or later, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / XP / 7 / 8 / 8.1
- Microsoft Certification
- Compatible with Windows 7
- 37 cm x 39.2 cm x 30.6 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 5 sec
- Fonts Included
- 45 x PCL , 136 x PostScript 3 , 13 x Intellifonts
- Printer Features
RAM
- 512 MB / 1536 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Weight
- 52 g/m² - 162 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m²
- Max Media Capacity
- 1600 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 150000 pages
- Networking
- Print server
- LDAP, 802.1x
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19752
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 1110 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- 37 cm
- 39.2 cm
- 30.6 cm
- 14 kg
