Product
Brand
RCF Over Head Speaker For False Ceiling Installation
Quicklinx: B2C3WS00 Mfr#: 13133042
The PL6X is a ceiling speakers featuring elegant and innovative design that can be flush-mounted in false ceilings or panels.
- Incorporating a 160 mm (6") loudspeaker.
- Both have a coaxial 25 mm (1") tweeter placed on a bridge support.
- The speakers are equipped with a line transformer that enables direct connection to constant voltage systems at 70V or 100V.
- The multiple sockets on the transformer make it possible to select the output power from among several values.
- Installation is quick and easy thanks to a special three-hook system that avoids the need for using screws and pallet or other attachment elements.
