Razer Wolverine V2 - Mercury
Quicklinx: GK98WS00 Mfr#: RZ06-03560200-R3M1
£74.17 ex VAT
£89.00 inc VAT
Razer Wolverine V2 Gamepad for PC, Microsoft Xbox One, Microsoft Xbox Series S, Microsoft Xbox Series X
  • Reforged to bring swift victory
    The ergonomic L-shaped hand grips of the Wolverine V2 provide a natural hold that outperforms its predecessor, while the contoured design and nonslip rubber grips allow swift and accurate button interaction for all-day gaming at peak performance.
  • Razer Mecha-Tactile action buttons and D-Pad
    Delivering hyper-responsive actuation with a cushioned touch, Razer Mecha-Tactile action buttons and Razer Mecha-Tactile D-Pad empower your every move with the perfect precision and crisp tactile feedback. Equipped with a 3-million tap life cycle for greater durability and a reduced actuation distance of 0.65mm, each button is finely tuned for greater accuracy to showcase your true gaming potential.
  • Extra buttons for expert control
    The Wolverine V2 comes loaded with additional buttons for advanced gaming, two multifunction buttons at the front of the controller can be remapped via Razer Controller Setup for Xbox to unleash greater control and a more personalized play style.
  • Unleash the firing frenzy
    Every millisecond matters in the heat of battle. For a competitive edge, activate Hair Trigger Mode via two slide-locks on the underside of the controller that greatly reduce travel distance to the main triggers, enabling an ultrafast rate of fire with a gentle press.
  • Easy audio access
    Game on for hours in comfort with the ease and convenience of plugging your 3.5mm audio device straight into the controller, instead of the console.
Razer Wolverine V2 - gamepad - wired
Gamepad
Wired
Controls
A button, B button, D-pad, X button, 2 joysticks, LT button, RB button, RT button, LB button, M1 Multi-function button, M2 Multi-function button, Y button
Razer Mecha-Tactile Action Buttons, Razer Mecha-Tactile D-Pad, mapping function, Hair Trigger Mode, built-in audio jack, built-in microphone jack
White
1-year warranty
Gamepad
Wired
Controls
USB
White
16.15 cm
10.68 cm
6.5 cm
274 g
Cable Length
3 m
Limited warranty - 1 year
Type: Game pad
Wired / Wireless: Wired
Compatibility: Microsoft Xbox Series S
Compatibility: Microsoft Xbox Series X
Compatibility: PC
Compatibility: Microsoft Xbox One
Brand: Razer
